Old 02-02-2010, 01:35 PM
your not missing much
Old 02-02-2010, 05:49 PM
did some more viewing, had dragnet on (badge with red background) purity has issues, I need to get a proper degauser ring, but will also check the built in deqausing coil to make sure it is getting activated.
Convergence and pin cusion look good on OTA broadcasting but I will put the dot bar generator on it anyway later.
Still need to tweak the color setup the white is a little blue, but other than that it looks great. Nice bright picture with plenty of sharpness.
Stereo has issues, one channel does not repond to the volume but does to the balance, and tone is wrong as well on that one. I will need to pull the stereo chassis out and go over it.
Its going to be easy to hook up the stereo to the aux and just keep the vc on the tv turned down (thats what I was doing when I noticed the stereo amp issues).
Of course I need to fix the filter caps and button down those boards, but this looks like its going to be a push over (well until that stereo VC issued popped up anyway). My guess is an open VC ground on one channel, hope its a pcb issue and not the VC itself.
Old 02-02-2010, 06:08 PM
there is a very brief surge thru the degausser. I wonder if I could use the built in ring and a varic to directly run the ring for a short peiod of time.
energize it, the ramp down the voltage slowiy, with the variac hooked directly to the unpluged degauser that is.
Old 02-03-2010, 12:09 AM
zenith2134's Avatar
Haha, yeah I know 8track was mediocre
Old 02-03-2010, 12:23 AM
darn stereo is turning into a tough dog...
one channel is fine, the other is some how bypassing the loudness/tone controls, you have to keep it turned almost all the way down on the balance pot to make it work.
I am 99% sure its not an open pot, but rather a decoupling issue. I had a problem like this a while ago, but I have done my normal checks of the audio decoupling caps and they test find and jumping them did not improve. I may have to did out the scope and see if I can see where the signal is getting in.
Argh... the TV was a push over and the dumb radio turns into a tough dog.
Old 02-03-2010, 01:11 AM
I give for now, def need the scope to see where this darn audio signal is coming from....
Old 02-03-2010, 06:20 PM
found a 33k resistor in the bass tone circuit that had drifted off to over 100k and since the bad side has no attenuation in the tone circuits i will start there.
I am feeding a audio sine wave into the tape input and then tracing with the scope comparing L and R (they are both getting audio feed thru two coupling caps to the same source). I could see a change in amplitude at one point which then I checked with the meter to find the bad resistor. Its kind of a pain since its a pcb with resistor up on end, so you have to measusre from the foil side and look at the top side to see the color bands.
hope this is it...
Old 02-03-2010, 06:44 PM
Ok, here is the deal, the resistor was ok (I was reading the wrong pad, again due to the upward mount of the resistor), but I got it fixed!
Very odd, It seemed like the signal was working upto a resistor, no signal on the side that comes from the pot, but signal on the side that goes to the amp, odd. I disconnect the jumper wire that connect the amp to the output of the loudness pot. no signal now (I have the pot turn all the way down, and signal was still getting amplified). hmmm I check the amp side no signal there either, hmmmm. I resolder the jumper and bingo its working fine now.
I have no idea what was going on, why the amp was getting signal with the loudness turned all the way down, but its ok now (I think, I am going to hook up and try again. very odd).
Old 02-03-2010, 06:50 PM
working perfect, man that was strange...
Now all I have to do is reinstall the stereo. There is no aux button like I thought. I may see if I can install a DPDT and put in a couple RCA inputs so I can choose between the Tape and the inputs of the TV.
Or maybe even get creative and do a DPDT relay that when off goes to the RCA for the TV tuner input and when on goes to the 8 track, then power it off the same power as the TV (maybe a pilot lite take off). That way when you turn on the TV the relay switches off tape and on to TV.
Old 02-03-2010, 07:55 PM
Reinstalled the radio in the cabitnet, hooked up the converter box to the tape in RCA jacks, I was wondering about the levels and if the volume would be right, worked perfect. While messing about with it I tried the turntable, seems pretty cheezy to me in quality. Its gonna need a little help the drive is not that solid, but at least the cart works.
Old 02-03-2010, 08:14 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
So, after all that, how does the stereo sound???
Charlie Trahan
Old 02-03-2010, 08:37 PM
It probably uses a BSR record changer and by the '70's, they were low quality. BSR went from cheap junk in the '60's to ultra cheap junk in the '70's. I will say that they usually work as intended once all the old grease is cleaned out and new grease applied where needed. Of course, you could always replace it with a better VM or Garrard changer.
Old 02-03-2010, 08:53 PM
actually I think it says Garrard on it, will get a pic later, I dont know jack about turntables.
Old 02-03-2010, 08:55 PM
Sounds pretty decent, and really very sensitive as I was able to get some pretty weak stations very well. I did not remember to clean the darn loundess control its just a touch scratchy, not bad just a bit.
Old 02-03-2010, 09:01 PM
Still very frustrated as to exactly what happened on the stereo.
My best guess is there was a tiny solder blob that I knocked loose near the input of the stereo when I desoldered the jumper that connected the amp to the volume control pad on the pcb. It looks like someone had put in a helper cap at some point, as it was zip tied to the chassis, but it also looked very factory in that it was zipped to a support that seemed to have no other function. I noticed the tiny blob and knocked it off when desolder the jumper.
Who knows maybe its been that way for a long time. You could use it the way it was if you just kept the balance turned almost off on one channel, and did not mind the mis match of tone (the overlly loud channel did not respond to any of the tone controls). I was too tired to mess with trying to figure it out, by then I just wanted it working as I was up till 1am last nite messing with it, even missed the rockford files...
