Old 02-10-2017, 07:35 AM
Radiotronman's Avatar
I agree that the clear silicone and clear double sided tape is definitely the way to go. If you do it neatly it will look just like new. Here's one I did last year.
Old 02-10-2017, 07:59 AM
Originally Posted by MadMan View Post
Also, guys, I was looking into fixing my cracked cellphone glass, and they use a uv-cured glue called LOCA to bond the glass to the lcd. Wouldn't it make sense to use that for this? It's not terribly expensive, it would bond the entire safety glass to the tube, be completely clear, and - I imagine - offer some implosion protection, as versus nearly none that the bead of silicone around the edge offers.
I looks like the orig system was to install the glass, use tape to seal the edges and then inject the liquid thru a small plastic port. Not sure how the glass was maintained a consistent distance off the CRT face. I did a quick of a 20x20X.1 volume of 40cubed inch, about 22 oz. Not sure if its sold in bulk for that kind of delivery.
Old 02-08-2017, 11:42 PM
From what I can find, cps stands for centipoise, a measure of viscosity.
Old 02-09-2017, 03:03 AM
Kevin Kuehn's Avatar
Workin' Late Again
Maybe fasten the glass back on using a few small evenly spaced pieces of double sided tape, then follow up with a fine bead of caulk around the outside to seal the dust out, or maybe even just use clear tape. I highly doubt silicone caulk will add much implosion protection. I'm thinking avoid the whole caulk mess.
Old 02-09-2017, 07:42 AM
I just use the foam tape, single side sticking, go all around the glass (not the crt) and use packing tap to hold it in place. The foam tape spaces the glass off the crt, keeps the dust out.
Old 02-09-2017, 11:46 AM
WISCOJIM WISCOJIM is offline
TUD1 = TheUniversalDave1
Old 02-09-2017, 03:44 PM
DavGoodlin's Avatar
Motorola Minion
Another Dave here....I was in a hurry and used what I had which was white silicone. I will be re-doing the attachment as it did spread inward so that it was seen at the sides of the 21" round tube.
Tom has the right stuff - GE clear silicone and I just bought some, maybe because I'm working on a GE
-Dave G
Old 02-10-2017, 08:30 PM
TUD1 TUD1 is offline
Just got through doing the RCA Colorama with the Zenith style halo. I used a heat gun, and about an hour and a half of my time. I had to force the wooden pieces in between the glass, and amazingly, nothing broke. I got the glass off just fine, with LOTS of heat. And yes, the green stuff smells like burning piss. I'll take the RCA style any day over the Zenith style.
Old 02-10-2017, 08:50 PM
Originally Posted by edison64 View Post
But as I stated the green cataracts can only be removed with a heat gun and lots of patience or a hot wire usually a guitar string hooked to an old battery charger you simply pull it through and it melts its way and boy does it stink
No need to run current through the guitar string or heat it....I've done cold guitar string zenith cat removals, and they work as well as hot does. Interesting that the heat gun method works, but I would still not recommend it due to the implosion hazards involved in the heat gun methods uneven heat...I've had RCA CRT faces crack from being unevenly heated by the sun so I'm a bit less of a fan of heat based cat removal methods than some.
I've always thought it smells exactly like a brand new out of the box inflatable pool toy....Magnified by like 30X.
Old 02-10-2017, 08:59 PM
Happy memories of my youth! Every time I get a whiff of that smell it reminds me of when we went to the Sinclair station to gas up Mom's car in the 1960's. They used to give away inflatable Dinos with a fill-up.
Old 02-10-2017, 09:48 PM
What did you say about implosion? I took care of that prior...
