Old 02-25-2012, 12:31 AM
I had originally refinished this cabinet with water based poly, but I've learned a lot since then. So I'm re-refinishing it using traditional materials.
The poly came off very easily with Citri-Strip.
Next, a little brown mahogany stain.
Then, grain filler.
I've used burlap in the past to remove the excess, but this time around I'm using a scraper. Really just an expired credit card. it worked out quite well.
I darkened in the pin-striping and edges with dark brown hobby paint then sprayed on some lacquer sanding sealer.
I applied a set of new gold decals to the control area.
Next up a little toner lacquer and the finish coats.
Old 02-25-2012, 01:26 AM
fox_rivers's Avatar
fox_rivers fox_rivers is offline
Then, grain filler.
Looks good! What was wrong with the water based poly?
Mastered soldering with paws.
Old 02-25-2012, 02:00 AM
Just like regular poly, it looks kinda "plasticy" compared to lacquer. Lacquer is also what they used originally. That being said, I have seen refinishing done with poly that looks pretty good and you'll find plenty of arguments pro/con poly vs. lacquer.
Personally, it took a while to get the hang of lacquer, but now I really like it.
Old 02-25-2012, 11:50 AM
Reece's Avatar
Reece Reece is offline
I always use lacquer since it's what was used from the early thirties on (shellac before that.) I keep a few old credit cards too, just for scraping off filler. Filler makes a big difference in the look and makes finishing easier as the pores of the wood are closed and it doesn't take as many finishing coats. Good looking job!
Reece
