Old 06-02-2008, 10:50 PM
Better stock up on DTV converter boxes. THEY ARE JUNK!
Well,
I'm the first to have the first DTV converter box failure, or atleast the first to report a failure on AK. I have the zenith converter box which is sold at circuit city, which is the same as the insignia box sold at best buy. While watching TV this evening with the box, the screen all of a sudden went into intermittent blue horizontal bars and then the unit shut off. I attempted to turn it back on and nothing. The red LED which is on when the unit is switched off even went out so its dead as a door nail now. No reset button on the unit. Wont respond to anything, remote or at the unit. Perhaps something in the power supply failed. Ive yet to investigate. Too late to get into that now. All I can say is that this is pretty poor. Ive only had the box about 1.5 months and it broke already. Im curious if more will fail as time passes in the near future.
This digital transition is a joke. More BS to deal with. Cheap crap converter box is an insult to the Zenith name. I think the quality fell out before the name went on with this thing. Whats next.
Old 06-02-2008, 11:08 PM
And I'll bet the warranty was only 30 days? About the only thing I'd know to do would be to check the caps in the power supply. I've fixed a few modern "throw away" TV's, DVD player's, etc. that had bad caps in the power supply. These caps that I'm finding to be bad are usually the cheapest "off the wall" thing they can find to cram in there. I don't know how the P/S circuit is in your unit; but, many of the switching power supplies in modern cheap junk don't have any sort of over-voltage protection. It's not uncommon for the B+ to run 10 times higher than normal and fry the rest of the unit.
From what I've seen of the inside of those DTV boxes, the power supply appears to be the only area that could be serviced easily. The rest of it looks to be all surface mounted parts that I would not attempt to unsolder!
I've got two Digitalstream boxes from ratshack but they are for future use since I have cable. I do intend to buy more boxes later. After reading this, I'd probably do just as well to buy the Funai made Maggotboxes from Wal Mart.
Old 06-15-2008, 03:52 PM
whoaru99's Avatar
whoaru99 whoaru99 is offline
I've read the Digital Stream boxes run extremely hot.
I've also read the Magnavox boxes have low sensitivity.
The Zeniths are still the overall favorites/top rated from what I've seen.....
push back against dubious claims that defy logic;
be on the lookout for misrepresentations;
question the lack of science when belief is the substitution;
be very skeptical when the denial of the laws of physics comes into play.
--jpaik
Old 06-15-2008, 11:10 PM
N9ZQA's Avatar
N9ZQA N9ZQA is offline
VK Member
At least in an unscientific, impromptu test conducted in my living room laboratory, the Insignia (Zenith) beats the Magnavox hands down in terms of sensitivity. I've got a Silver Sensor antenna on the ground floor pointed in the general direction of downtown Chicago (35 miles away) and can receive all of the local channels with either box. However, there is a PBS station in Gary, IN which is impossible to pick up with the same setup using the Magnavox, but it comes in with acceptable signal strength using the Insignia.
Still keeping an eye on the reviews as I have one coupon left...
-Jim
Old 06-17-2008, 12:12 PM
fdrennen's Avatar
fdrennen fdrennen is offline
Organist in Residence
I have two digital stream boxes and they do run hot. I will be on the lookout for a zenith for the third!
DTV= Disgusting Terrible Vision
"My goal is to live the truly religious life, and express it in my music...My music is the spiritual expression of what I am - my faith, my knowledge, my being." - John Coltrane
Old 06-25-2008, 08:07 AM
Tony75's Avatar
Tony75 Tony75 is offline
I'm not really convinced that digital is better than analogue for TV ...yet!
My parents live in an area of Sydney that is fairly close ~12km to the transmission towers. Analogue TV is fine except for one channel which seems to get a bit of ghosting. They also have a few planes flying overhead as there is a beacon for the airport nearby. This causes a shudder on analogue and a momentary total loss of signal on digital, and depending on which box is used, a horrible sound through the audio. There are also numerous random glitches where the picture just pixellates and becomes unwatchable, also the muting cuts in and blue screens. This is experienced over a number of houses, a number of different STBs and various aerial solutions. But they all lead to the same conclusion, the level of technology in these boxes, and the digital broadcast is simply not yet good enough and we only use the STB for channels which are only on digital, the rest of the time we use analogue. It can only be worse for country areas. Rain also seems to upset it, which is pretty poor performance. Plus digital channel changes are very slow.
Some boxes get very hot, these usually fail within a couple of months, usually with bulging, leaky electrolytics in the power supply.
I have found here that a few Topfield units have given good service, they can even survive a time submerged, when they were removed from the Hunter river last year after the floods, two plain Topfield boxes were OK, the Topfield PVR worked for a few more months and the LG box never worked again, they were all off at the time.
I have found that extended warranties, which I usually avoid, are a good idea with set top boxes.
Cheers
Tony
Old 06-25-2008, 10:03 AM
MRX37 MRX37 is offline
I'm on the fence about that. I certainly don't want Analog TV to leave, if anything, just for emergency use.
Here are some pros and cons I've gathered from my experience with DTV:
PROS:
More channels
No fuzzy picture/ghosting/color drop out/ sound hissing/crackling.
Higher resolution AKA: More detailed picture. On a standard analog TV, it looks like you're watching a DVD.
Good reception with a rooftop antenna.
CONS:
Reception issues when using anything less then an outdoor antenna. Getting distant channels from other cities may prove difficult to impossible. On windy days, you may still get picture drop outs that last for a half second. Very bad when trying to record something.
Some channels are over compressed, leading to compression artifacts, especally during motion.
Changing channels is slower. Even back in the days of dial TV's, one could click through the dial much faster.
Now, I think that with time, DTV will iron out these flaws better. As it stands now, I don't want Analog to fully disappear yet.
Old 06-25-2008, 01:42 PM
NowhereMan 1966's Avatar
Slave to 1 Cat
Cheers
Tony
I live in a flight path here in the Pittsburgh, PA area, many times, I get pixelation when airplanes fly over although I've seen a small increase when it rains hard or wind blows, we have trees in the back. I didn't notices as much pixelation when it was winter and the trees were bare. Here in Pittsburgh, all HDTV are on UHF channels but a few will migrate back to VHF after the change so I'm interested to see the effects on that. I have three boxes, my aunt gave us her second one, 2 Zenith (LG really) DTT-900's and one DTT-901.
Old 06-02-2008, 11:11 PM
jonman jonman is offline
Could it be your box was meant for sale at Walmart?
Old 06-02-2008, 11:45 PM
And thus, like its 90's TV's, Zenith DTV boxes also don't last very long...
Seriously though, 1.5 months is not very long. There should be some kind of warrenty, and if there's not, the box is shit and another brand would be a better buy.
Old 06-03-2008, 12:01 AM
I just had another thought. The Maggotboxes have a master power switch on the side of the unit. Leaving the master power switch off on those boxes, when not in use, may lenghten it's life.
My cousin has had his Maggotbox Wal-Mart special DTV box for a little over a month and it's not given him any problems.
Old 06-03-2008, 12:14 AM
I actually have kind of a failure to report as well.
I bought my WinTV HVR 1600 TV card mainly to check out all these DTV channels and see what DTV was like. DTV is okay, but the HVR 1600 is turning out to be a piece of shit. It works fine in analog... all well and good, but I didn't buy it for analog. I have several analog TV's so I'm covered as far as analog goes.
Depending on what drivers I use, DTV channels either stutter, or I can't record DTV video. The card is a finicky bastard when scanning for DTV channels... to the point where I have to manually input them. After a LONG talk with hauppauge's tech support, they finally said my card is most likely defective and that I should return it. I'll exchange it for a new one tomorrow, or I'll damn well try to.
Old 06-03-2008, 12:29 AM
Bill R Bill R is offline
I have yet to see any of either the RCA or Magnavox converter boxes returned at my Wal-Mart.
Bill R
Old 06-03-2008, 01:05 AM
dr.ido's Avatar
dr.ido dr.ido is offline
Perhaps it would be an idea to replace the caps with something decent as a preemptive measure before they fail if you intend to keep these boxes long term.
Power supply faults in set top boxes are common. I've fixed 20+ of them and scrapped countless more (dead set top boxes are the cheapest source of certain power supply ICs).
Old 06-03-2008, 01:37 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
If you really wanna keep them running, make an outboard regulated power supply instead of the cheap switching power supplies. 8 out of ten times the PS is what makes the machine crap in this case.
Jordan
