Old 12-01-2003, 07:51 AM
Chad Hauris's Avatar
I think that brake cleaner and Radio Shack tuner cleaner are similar...it is tetrachloroethylene?? or something like that. Brake cleaner smells about the same. Have not tried it, but would probably work OK. However I only use DEOXIT for contact cleaning. It is expensive, but it is the best! Have not had a recurrence of the trouble on any controls I used Deoxit on, after years of use.
I agree that WD 40 is not great, do not even own any of it. PB Blaster is good, it has loosened rusted parts on mowers, 30 year old rusted spark plugs, etc. Also used KROIL at work, loosed up a rusted old satellite dish mount.
Old 12-01-2003, 08:12 AM
captainmoody's Avatar
captainmoody captainmoody is offline
WD-40 is the last thing I would use on pots, You need something with a cleaner and lasting lubricant.
When I used to repair copiers, One of the techs at where I worked would use that on the one way clutches. Yeah, They would work fine for a week or so then cause trouble again when the lube evaporated.
He started using the proper cleaning procedure and the right grease and all the return calls ended.
Old 12-02-2003, 11:32 PM
When I was working on an old radio a couple years ago, I bought a can of Radio Shack tuner cleaner (had to get a new pilot light for the set anyhow, which is what I went there for in the first place). Their brand of tuner cleaner is expensive as all get-out ($7.99 or so, if memory serves), but it worked well. Don't know who makes RS branded tuner cleaner (perhaps they make their own), but no matter. It works, which is all that matters to me.
Old 12-15-2003, 07:11 PM
polaraman's Avatar
<--1956 300B
Got this set off the CURB in Atlanta this past Saturday. best kind of TV set - FREE! Tried it tonight and no vertical deflection. The rest of the set Seems to be fine. Does anybody have the knobs for this set?
polaraman
Old 12-15-2003, 07:22 PM
Wow! did you bring that home in your neon? My back hurts just looking at that!
The reason I say this is Doug and his friend Joe came up from Chicago and helped me move at least a dozen consoles to my new house, Carmine helped too the week before. Had to be about 30 consoles in all and I am not feeling well.
Oh well, At least it is done and nothing had to be left behind to an uncertain fate!
Is that an early seventies Hybrid? I have seen those before but can't remember.
If tube deflection, Check the vert out. If that is good make a few voltage checks in that circuit to make sure there no open power resistors that feed it. Lastly, Check caps.
Old 12-15-2003, 07:37 PM
polaraman's Avatar
<--1956 300B
It is a hybrid set. Looks as it can be fixed easily. I had my truck this time. I will take a picture of the chassis tomorrow.
I went to Minnesota last year in my Neon and got my Stromburg- Carlson Classic 21. Took out the passenger seat and set it in there. The chassis rode in the back seat and the cabinet was beside me all the way. I had them measure the set three times so I was certain it would fit.
polaraman
