Old 08-19-2019, 11:38 PM
I started on the radio chassis this evening. After taking the usual pictures, I gathered all the capacitors and resistors.
As usual, I restuffed the 1 dual E-Cap and installed it.
I then noticed that this chassis uses 2 Couplates! Centralab PC-81. Looks like I'll be making some new couplates.
Tomorrow my grandson is coming over and he likes to solder so he'll help me with the recap.
Old 08-20-2019, 11:01 AM
Notimetolooz's Avatar
Originally Posted by mr_rye89 View Post
the vertical integrator in my TV calls for 1000pF and 2000pF capacitors, will subbing ceramics there screw anything up?
I believe there would be no problem with ceramic disc capacitors. MLCC are multilayer ceramic capacitors. However I would select disc caps with fairly high voltage rating, maybe 500V or more.
Old 08-20-2019, 11:43 AM
Also want temp stable IIRC C0G rated parts.
Old 08-20-2019, 12:35 PM
Does anyone have any reference books for couplates?
I have been looking online and have yet to find much info on them beyond individual breakdowns on the schematics. I would love to find a manual that had all of the values listed through part numbers.
Old 08-20-2019, 01:50 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
okay thanks I used ceramic caps rated at 1kv and I don't think there's problems with sweep on the TV I'm working on, likely video output. But I'll address that in a different thread.
I'm not a fan of these couplates/PECs/modules whatever you call em. I do make my own but they aren't nearly as nice as the OP's.
Old 08-20-2019, 03:20 PM
This radio has one of these things in it. Seeing I have no documentation, what is it? I think it must be a transformer or some type of matching network.
Old 08-20-2019, 03:43 PM
I believe it is exactly what you think. I've seen that exact style a couple times before, they normally don't fail so I usually ignore them.
IIRC some were used as mains power noise suppression chokes, but I think I have seen that style in other applications.
Old 08-20-2019, 04:40 PM
init4fun's Avatar
init4fun init4fun is offline
I believe the item in question is the local oscillator coil
Old 08-20-2019, 04:44 PM
Makes sense! Thanks.
Old 08-20-2019, 04:47 PM
Well, it's got two windings, and since there's no other item above or below the chassis resembling an oscillator coil, it's just about gotta be the osc coil.
Edit. OOPs y'all already nailed it.
Old 08-20-2019, 10:31 PM
Well, it plays after recapping. My grandson came over and helped with about 75% of it. He did pretty good.
It'll need a good alignment and tomorrow I'll work on the details like cleaning and lubing the tuning cap, increase dial cord tension, etc.
Old 08-21-2019, 07:36 AM
init4fun's Avatar
Your welcome . Anytime I can help someone who does such great work on the restorations that you do I am truly happy to help . I've read your "Galloping Ghost" work over at RCU and you have serious electronic skills !
Old 08-21-2019, 10:57 AM
Thank you.
Old 08-21-2019, 11:22 PM
I spent the day making up some boards for the Couplates. I also made up some boards for the Vertical Intergrator so I now have some spare of each.
After making up the boards I assembled the 2 that I needed to finish this radio.
I installed them and then did another check of the radio. It worked well even though it hasn't been aligned.
Old 08-21-2019, 11:49 PM
freakaftr8's Avatar
Convergence freak!
Wow looks amazing! Great job! Bet it will play better than when it was new! Those couplates must take some time to make.
