Old 05-01-2012, 02:41 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
I found a set with a 9-160-05, and R3201 is 1k ohm carbon composition. It looks like all it does is ground a couple of spark gaps, so I would check for a shorted spark gap (should be easy to find by following the PCB traces). Other than that, it may have been taken out by a power surge. Either way, it should have no effect on the performance of the set.
Right on the money Andy! E3521 is shorted out! R3354 is kinda low (390 ohm 10% 5W) down to 374 ohms.Do you think this would have any effect on my "width" problem that i'm experiencing? or should i look elsewhere?
"IPC 610 Class E & J STD-001 Certified"
Old 05-01-2012, 07:02 PM
Old 05-02-2012, 03:49 PM
mrflex65's Avatar
Well, i'll be damned!It works!
I had to do ALOT of resoldering on all three modules,especially on the 9-160 which required some pad/trace repair as well
Regarding the two bad parts,it apparently works fine without them!
Should they be replaced or leave well enough alone?
Oh,and by the way,thank you very much for all your help Andy!
Old 05-02-2012, 04:17 PM
jstout66 jstout66 is offline
It looks GREAT! I'd leave well enough alone.......
Old 05-02-2012, 07:32 PM
mrflex65's Avatar
I think i will!
