Old 06-21-2010, 08:19 PM
I did notice the Horz out tube getter was getting brown around the edges. Is there a way to check to see how it is doing in circuit? I dont have a tube tester that can test it.
I suppose the only thing I could check is the HV but that could be effected by the HV rectifier, and or the regulator tube correct?
oh and the tube that is in there is not an orig its a Lindal brand and not the specified tube number.
Old 06-21-2010, 08:28 PM
I still need to pull the tuner/control panel, the tuner is just too flaky and I would hope that a cleaning will get me a more consistant pic. Also the VC is very noisey. I did replace the 6Z10 (audio detector/amp compactron) which did help the volume which was a bit low.
The AFC switch seems to have no effect what so ever, I assume it works like any other AFC to lock on to a signal.
The fine tuning control seems to have stopped working as well (afc off) it does not have any effect when pushed in and turned. I hope I did not strip anything with the frequent adjustments I was making, but at least it seems to have stopped on a good pic.
OR maybe the switch on the AFC is simply broken and its stuck in the AFC on. It was very balky. Anyway I will check into that when I get the tuner out for cleaning. That will also be the time I attempt to unstick the concentric UHF tuner.
Old 06-21-2010, 08:35 PM
Finding the correct number and a better brand of tube might help. Some say a tube is a tube but that is not so, I've had bad luck with the few Lindal brand tubes I've encountered. They seem cheap, might not be regulating very well. Also, some of those tube numbers that are supposed to cross don't always act right in the circuit. That's why I like to put in exactly what is on the schematic or tube diagram.
Old 06-22-2010, 01:28 PM
I tried a new way to set the grey scale since I was not having any luck with the setup switch method. I use the DTV converter box and disconnect the antennal, this gives me blank dark screen with a "no signal' sign.
I use the screen drives to set the background to a neutral none color background, adj the focus.
put the antenna back on and adj the CRT drives (blue and green) so that adj the color level gives a decent color tracking as I turn up and down the color control.
Old 06-22-2010, 07:34 PM
pulled the tuner, it did not seem too dirty, but I did some brown off the fingers and the tuner strip buttons.
Next up was to free up the UHF. 1st I separated the tuner from the picture and volume control panel. Next up I removed the outer plate that allowed access to the stuck main UHF gear that drives the channel indicator. Removed the large circlip, worked off the stuck gear, sanded the inside with a socket wrench and sand paper to make a drum sander that would fit. worked it by hand, testing the fit as I went. when is seems free enough (turns easy but no slop) I put a bit of tuner lube on it ( I guess its safe on plastic and will not gum up) put it all back and reset the UHF indicator. replaced all the circlips, buttoned it all back up. Cleaned the tuner tube pins while it was out. The only casualty was the color knob, it cracked coming off. Some super glue and strong sewing thread wrapped around it and glued pulled the crack up tight.
used some pot cleaner lube on the VC and the pesky afc switch while it was out. Popped out a few strips on the tuner get get access to the fingers, channels 6-10, I never remove 3 or 4 just in case I were to break one.
the result, perfect tuning, not more snow etc.. no more critical setting. The UHF still seems a bit tight, but its not the gear. I did lube the UHF tuner shaft, maybe it will loosen up with use. It works fine just seems a bit tight. The fine tune on the UHF work as it should. I was able to get some OTA analog using it.
The UHF fine tuning is working again as is the AFC switch, and best of all the audio is perfect now, no more jiggling and fiddling to get it right, and volume is up across the board.
I will button it up later and get some screen shots. Over all the tuner was not a big deal at all.
Old 06-23-2010, 03:54 PM
well I have been watching it some more and still not satisfied with the pincushion correction. I put a scope on it and examined the output of the waveform from the plate of the pincushion tube, I noticed a a lack of a waist in the form. It had some just not what is showed on the sams. The P-P value was was off also, not sure what that is all about.
there is a resistor/cap network in the grid of the pincushion tube. I tried increasing the cap value, and the waist got wider not smaller. So my next check will be to take the cap out of circuit and check it.
There is also a 100mfd electro that comes of the cathode of the vertical output tube, it looks like that is the source of the vertical componet of the wave since it looks to bias the tube at the cathode. Its a little over my head what it is doing but I will start there.
Old 06-23-2010, 05:14 PM
I think I get the pincushion circuit.
looks like a horz pulse it applied to both the grid and the plate of the tube, the tube bias is controled by cathode bias which comes off the vert out transoformer.
So since pincushion correction along the top needs to have the vert deflection oppisite directions when on top and on bottom, the correction is derived by having the tube cut off (due to bias) and only the plate input of the horz being the driving force of the vertical adj (a cap smooths the horz pulses and applies to the vert yoke thru the pincussion adjustable transformer which is tunable I presume to the hors freq.
when the tube is NOT cut off by the cathode pulse then in conducts from the grid input of the horz freq, this gets inverted in the tube and nulls out the pulse at the plate, this is the waist I see on the scope.
Since the waist is not thin enough (i think) I have to presume either too much plate pulse is coming thru the cap that goes to the boost, or the tube is not conducting enough to null it out.
The grid of the tube is fed by a 220pf cap that goes to the same boost souce so it could be that it has developed some kind of interanl resistance (I doubt this since its a disk, OR the plate feed cap from the boost is perhaps leaking or drifted up in value (not sure about all this). Its a white ceramic tube .0012 1kv cap, so its prob a paper inside.
I recall my pulse at the plate was much larger than it should have been (which would explain the inablility of the tubes inverted pulse being able to null it out.
I am kind of suprized that zentih to not provide for an amplitude adjustment to the pincushion adj. the adjustable transformer just seem to tilt the correction more that increase/decrease the amplitude of the correction to the yoke.
Old 06-23-2010, 07:33 PM
well turns out the cap in queston was a disk cap .0012 1kv.
I really doubt it is the problem, and there is not much else to this pin cushion circuit. I did replace on of the Ecaps, a 100uf, no change, did replace a resistor in the grid circuilt of the pincushion tube it was a 15k that read 20k (10% banded), no change.
anybody else with this chassis have pincushion (top mostly) issues?
Old 06-23-2010, 09:37 PM
freakaftr8's Avatar
Convergence freak!
Dave, how many Zenith sets do you have of this vintage? I have a 67 and a 66. Both have pincushion issues on the top. The bottom is pretty good. I have two RCA CTC-17's that have not perfect pincushion too. I have never figured out if it's a problem with the set or if it's just the way it is. Pincushion on older sets always seemed to be a little bowed on the top. If anyone else thinks this too or if I am wrong, please chime in.
Take a pic of the raster with some vertical lines or something we can see the pincushion.
Old 06-23-2010, 10:22 PM
marty59's Avatar
marty59 marty59 is offline
I've noticed top pincushion issues on early RCA's and clone chassis' too. Pretty common. Been awhile since I've seen an early Zenith..can't recall on that.
Old 06-23-2010, 10:47 PM
I will get some pics tomorrow
Old 06-24-2010, 01:52 AM
freakaftr8's Avatar
Convergence freak!
Another note, I have had three roundies, An RCA CTC-16, an RCA CTC-12 and an Airline (Magnavox), none of these sets excerpted pincushion issues that could not be adjusted out. All these sets after a proper alignment had great pincushion. Something happened with the introduction to the 90 deg rectangular CRT. I just fired up a 66 Magnavox with a 25GP22. Yup, bad top pincushion. Either it's as good as it's goona get or it deflects in the center the other direction with the areas on the sides of the CRT about 2" still bowed up so the effect would be a wavy line if you will. The round CRT did not have this problem because there are no edges you can see. The CRT is perfectly round.
I have a '69 Sony KV-1220U. Believe it or not it has a slightly distorted upper pincushion as well with no way to adjust it out. I have seen this with the early Sony's. The KV-7010UA (the very first Trinitron) has a distorted upper and lower pincushion.
also a late 60's Hitachi CFA-450 13" has horrible upper pincushion, bottom not bad. Not adjustable.
I noticed that around the 1975 model year sets (foreign and american) seemd to get the pincushion spot on.
Old 06-24-2010, 02:13 AM
freakaftr8's Avatar
Convergence freak!
Actually, looked back at the pics you posted in page 1. That pic of the test screen, looks pretty much like my Zenith and RCA pincushion. Now there are two things that come to mind. Does your pincushion pot hit the extreme end before the pincushion is out or does it distort the top center the other way but leave the edges of the raster still bowed upwards? Cause it should honestly have an adjustment variation to at least go both ways I believe. At least the Zenith I just messed with to check this out will.
Old 06-24-2010, 06:03 AM
on mine its a coil, as you adjust it, the pincussion compensation is like a small wave that you can move along the top, trying to center the wave seems to be the idea, but the wave is just not wide enough so be best i can do is to pullup the center. My guess is that this is just the limit of the adjustment, and before letter box for other narrow view formats it was not an issue as the only time I see it is when graphics or narrow formats are displayed.
Old 06-24-2010, 03:35 PM
freakaftr8's Avatar
Convergence freak!
That sounds about right the way you described it.
I guess you could try the alignment of the yoke. See if it shifts up and down vertically like a pivot. If it sinks down in the rear that can cause poor upper pincushion.
