Old 04-07-2009, 09:57 PM
MRX37 MRX37 is offline
Okay: Here's the voltages for each pin. They're all way too low...
Pin 1 measures at 0 volts
Pin 2 measures at 0.75 volts
Pin 3 measures at 0.18 volts
Pin 4 measures at a whopping 2.0 volts
And pin 5 measures at 0 volts.
All these measurements were taken with the HOT reinstalled.
Old 04-07-2009, 10:08 PM
Check the voltage at both ends of R007, the 5.6 ohm, 2 watt resistor that I think you replaced. If you have roughly 150 volts on one end; but, nothing on the other, the resistor is open. If you have little or no voltage on either end of the resistor, recheck the voltage at the positive terminal of the large 470 uf, 200 V cap. If you have voltage there but not on resistor R007, there is a problem between the cap and resistor. Maybe the trace is broken.
Did you check the new HOT to make sure it didn't short when you first powered up the set with the new parts?
Old 04-07-2009, 10:20 PM
The new HOT is good, the new resistor is good. I tested them both before they went back in. I doubt the trace is broken. is there anything between R007 and the main filter cap?
Old 04-07-2009, 10:31 PM
Not on my schematic. If you use your ohmmeter to check between pin 3 of the regulator (which one end of R007 connects to) and the plus side of the big filter cap, you should read around 5.6 ohms. With the set off and unplugged, I'd measure the voltage across the 470 uf filter cap to make sure it's not holding a charge. If the cap is holding a charge, (and it very well could be) it will get your attention in a most disturbing way if your not careful.
Old 04-07-2009, 10:44 PM
Okay, 470uf cap showed no voltage, so I measured between the plus side of it, and pin 3 of the regulator IC, and got around 11k ohms.
Old 04-07-2009, 10:57 PM
OK, now I'm starting to get confused and that ain't good. It sounds like you are checking from pin 2 instead of pin 3 of the regulator. There is a 10K resistor between pin 2 and the filter cap. One end of R007 should connect directly to pin 3 of the regulator. Did you check R001, a one ohm, six watt resistor? It's in the power supply area.
Old 04-07-2009, 10:59 PM
I took R007 out of circuit after following the trace from the positive cap lead to the regulator, and finding that it was the only resistor in the circuit.
r007 is bad.
now I'm confused, as that resistor tested good two hours ago.
Old 04-07-2009, 11:01 PM
Recheck the HOT again to confirm that it's not shorted. If it's good, the only other thing I can think of is to change the STR30130. They should only cost a few dollars. If you don't want to order one, just sit the TV back. It's a common IC in '90's TV's and I'm sure one will turn up in some junk real soon.
Old 04-07-2009, 11:06 PM
So, if it's not the HOT, then it has to be the STR30130?
I have more then a few boards from 1990's TV's maybe I have one....
Old 04-07-2009, 11:15 PM
Nope. no STR30130 IC's in my stockpile. Guess I'll have to scrape enough together to order one. One of my Zenith chassis has a big regulator IC, but were i to guess, they aren't as interchangable as HOTS are...
Old 04-07-2009, 11:19 PM
The Zenith will probably have an STR53041 and it won't work. If you have any STR30xxx series IC, you could try it to see what happens. The last three digits of the STR30xxx line indicates the output voltage. There were STR30120's, 125's, 132's, etc.
Old 04-07-2009, 11:29 PM
No STR30xxx IC's. The Zenith IC is an STR 60XXX IC
Just tested the HOT again and it's not shorted.
Old 04-08-2009, 12:14 AM
And, when you order that STR30130, try to get it from a place like MCM or tritronics. Many of those $1.99 discount house specials are not worth the effort. Many won't work at all and others will work for a while and then bite you in the butt.
Old 04-08-2009, 01:00 AM
Yippie.
First I'm going to try the two local TV repair shops around here. It's apparently a common IC. I might get lucky.
Of course I need the cash first. I already cashed in the pop bottles to get the 5.6 ohm resistors.
It's too damn bad those 2003/2004 JVC chassis I have don't have the right IC... nothing wrong with those chassis. Just pulled them cos the CRT's were weak.
Old 04-10-2009, 04:51 PM
Well, I sold that POS Zenith and now have the cash needed to order the IC. MCM has them, $3.79 each, apparently including shipping. I think I'll order two. Always good to have a spare.
