Old 04-21-2008, 01:59 PM
Those rectangular stand up things are resistor packs. There are many resistors in there and about the only way you can check them is to have a schematic of the part, which they don't often provide.
Anyway, I'm glad you've got a board on the way and I hope it fixes your set.
Old 05-01-2008, 01:05 PM
Tugboat Tugboat is offline
Banned
Just thought I'd give an update. So far the replacement board I purchased hasn't arrived. It should have shipped on 4/21, but the guy said he would send it on 4/24. According to the tracking info, he must have sent it on 4/26. It should have been sent priority, but who knows. Hopefully it will arrive today.
On another issue, my vcr has developed an playback audio problem. Lately the audio will drop to a very low and staticy (is that even a word). Using the tuner yields perfect sound, so I figured I'd check out the playback head. The head is mounted on a small circuit board with a resistor across the terminals. I got a replacement resistor and while playing a tape, I touch its leads to the existing resistor. When I did this, the sound came back. When I took it away, the sounds was still there. I stopped playback and pressed play again only find the sound problem back. This time I was poking at the two wires soldered to the head to see if there was a short in them. During playback, if I touched the leads at the solder point, the sound would crackle and get louder. When I took my finger away, the sound would go back to static. For some odd reason, I decided to short the leads momentarily with a wire and what do you know. The sound came back. Now, each time the sound goes to static, I short the leads on the head and it comes back.
I checked the head and it checks out okay, so I'm thinking it's cap on the audio board. When I short the leads, I short the bad cap. Does this sound like I'm on the right track? I have the Sams Photofact for it, so I should be able to test the board. At least the section that the PB is connected to as the audio for the tuner is fine.
Thanks!
Old 05-01-2008, 01:13 PM
I sure hope you get that part. Often, I've had sellers send items via "ultra snail mail" with no insurance even though I paid for priority with insurance. They pull this crap so they can make money (rip people off) on shipping. Shipping prices / tactics have gotten so bad that I'm having to cut back on my ebay purchases.
I really don't know what to tell you on the VCR. The best test for that resistor would be to unsolder it and check it with an ohmmeter. Bridging another resistor across the old one will result in lower resistance than the original, unless the original is open.
Old 05-01-2008, 01:18 PM
Banned
I tried the removed the resistor and it was good, so it's back in. The problem seems to be on the audio board itself. My brother says that when I short the leads, it sounds like I'm shorting a bad cap as well. That's why the sounds comes back. Just thought I'd check here to see if anyone has experienced this problem before.
I sure hope it wasn't sent any other way than priority. The shipping was high to begin with.
Old 05-03-2008, 02:21 PM
Banned
Radiotvnut -
I've been checking ebay for a crt tester. You mentioned earlier about a Sencore CR70 and on ebay there's a Sencore CR168 Big Mack with a total of 16 sockets (can't tell if one will fit my tube). Is it safe to assume that the higher CR number means it's newer than the one you mentioned? Also, do you know what socket my tube would need for that model?
Thanks!
P.S. Still no replacement board yet! I bet the guy didn't mail it the day he printed the shipping label.
Old 05-03-2008, 03:47 PM
Originally Posted by Tugboat View Post
Radiotvnut -
Thanks!
I can't tell if there's a socket with that tester for your tube. I do know that the CR168 is older. The CR70 is next to the newest Sencore model. The CR7000 is the latest Sencore model. I don't know the socket number for the sencore. The B&K socket is "CR20" for B&K models 467, 470, 480, and 490. If you find a B&K tester, ask the seller if it comes with the CR20 socket. I've never used the Sencore models. All I know is what I've read about them. I know a guy who has a B&K 470; but, he thinks he should get about $300 for it. I can't see it happening, though. If I can talk him into selling it for a more reasonable price, I'll let you know.
Concerning that board, I hope you're not dealing with a deadbeat seller. I'd contact him and verify that the part had been shipped.
Old 05-03-2008, 03:56 PM
I found two B&K 470's on epay. One has the CR20 adapter and I can't tell about the other one.
http://cgi.ebay.com/B-K-470-Picture-...QQcmdZViewItem
http://cgi.ebay.com/B-K-470-CRT-TEST...QQcmdZViewItem
Old 05-03-2008, 05:34 PM
Banned
I'll check out the two you found on ebay. My brother works on sets (mostly 40s and 50s). I might be able to get him to chip in and he can keep it when I'm done.
I have tried for the past 5 days to contact the seller, but he won't respond. I've requested the seller's information and am going to call him. USPS only shows the electronic label being created on 4/25, but not of receiving the actual package. So I'm going to relax before I call.
Thanks for the info.
Old 05-04-2008, 09:10 PM
Banned
Well I won a B&K CR470 with the CR20 socket on ebay today. Got it for 10.60. Let's hope it works!
Old 05-04-2008, 10:07 PM
MRX37 MRX37 is offline
Good for you. Hopefully your CRT is in good shape still...
Old 05-05-2008, 12:13 AM
I hope it works for you and I hope this seller is quicker than the other guy at taking care of business.
Old 05-05-2008, 12:21 AM
That socket number 3 is a good one to have on hand as well. It test the rectangular delta gun tubes from the '60's and '70's. If you can get CR23 and CR31, (B&K probably still carries these) you can check the newer inline gun tubes from the '80's - present day.
It won't be a major problem if your tester does not have a manual and/or a setup chart. I can tell you how to operate it if need be.
I don't think you did wrong at the price you got it for unless it's totally burned up. Those models didn't give that much trouble.
Old 05-05-2008, 11:43 AM
Banned
This unit didn't have many sockets, but for $25 shipped, it's worth the risk.
I'm searching the net for copies of the manual and setup chart, but not having much luck. I might need to ask for assistance to make sure I'm doing things correctly.
If I can get this guy to drop it in the mail today, I can have it by wed or thu (priority from IA). If the output board arrives, I'm going to hang onto it until I can test the CRT. So sense risking the board if the tube is toast.
Old 05-07-2008, 05:24 PM
Banned
Okay, got the CRT tester today and I downloaded the general instructions for it from B&K. The CRT tested fine and installing the new video output board brought the set back to life.
I have the service manual (PDF) for the set, but it sure doesn't make things easier. It figured out that U8 mentioned in the manual was a connection on the sync. A.C.G. board and that when it's grounded, the show goes away and I can then set the brightness limiter and range controls. I was also able to set the G2 control to produce a dim raster. But that's as far as I was able to go/figure out.
The set produces a decent color picture with just the G2 set. The red, green and blue controls on the board are at their minimum settings. What am I supposed to do with these adjusters? I must need to do something with them or why else would they be there.
My brother says there should be a "setup" switch, jumper or something like that. The manual keeps referring to G2 and color controls...turning down all, then turning one up to get a raster of that color gun in the center of the screen and check for it being uniformed across the screen, blah, blah, blah. When I turn one of the color controls, the snow on the screen starts to take on that color. The manual doesn't say I should ground U8 for this adjustment, so how do I get rid of the snow and get to the raster?
Don't mean to babble so much, but I'm a bit confused at the moment.
Thanks!
Old 05-07-2008, 06:50 PM
