Old 05-21-2006, 09:08 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Originally Posted by wa2ise
Of course if you wanted this set to last, you'd restore the old chassis. It would last about ten times longer than the Chinese color TV chassis....
55 years old and all it needed were a few adjustments and contact cleaner to get a decent picture. Beautiful copper chassis.
Anyone hear of this? The internal speaker was disconnected. A 'SPKR' outlet on the rear chassis was clearly used as it was still shiny. Maybe a table model TV that slips into a console?
Old 05-21-2006, 10:18 PM
Dave S's Avatar
Dave S Dave S is offline
<-- Me and my "first" TV
Originally Posted by Pete Deksnis
More amused than ticked I guess at finding the empty connector: hardware of the day actually seemed to support the historic record. And the lesson only cost fifteen bucks.
Pete,
You have a genuine piece of history there: early analog vaporware!
--Dave
Old 05-21-2006, 10:35 PM
Steve K Steve K is offline
Pete:
I just looked in Wallace's Admiral book and it states in there that on very late production runs the wiring to the color sockets were omitted. Early runs supplied B+ and AC to the converter and a plug was needed to complete the B+ circuit if a color converter was not connected.
Steve
Old 05-22-2006, 12:21 AM
Originally Posted by Steve K
I just looked in Wallace's Admiral book and it states in there that on very late production runs the wiring to the color sockets were omitted. Steve
Well I guess that's it then...
Built after it was clear CBS Color flopped.
Did Wallace perchance have data on the CA100?
Old 05-22-2006, 01:08 AM
polaraman's Avatar
<--1956 300B
The SAMS is 135-2. It shows the socket but not how to hook it up. It also says that the "N" has no service significance.
Do any of the connectors on the Colo-r-tel or CBS color wheel systems match the socket on the back of the Admiral?
SAMS does not list a CA100
polaraman
Old 05-22-2006, 01:14 AM
Pete:
Wallace's has no info on a CA100.
Old 05-22-2006, 07:05 PM
vintagecollect's Avatar
glad did not bid, wanted tv with adapter eventually. FCC hearings probaly made color wheel obsolete quickly. Does bidder have CBS wheel info? must be same or similiar to other CBS sets? A good project, albeit a very specialized one. If someone gets this whole thing going, pics please!!
Old 05-24-2006, 12:45 AM
cbenham's Avatar
cbenham cbenham is offline
The perceived color over B&W TV was an invention of James Butterfield. There is an article about it in the October, 1968, issue of Popular Electronics. I remember seeing
a B&W commercial with the 7 UP logo flashing in color at the end for several seconds.
I was working as a cameraman at a local TV station at the time and Engineering would warn the receptionist every time the spot was going to play because the phones would ring off the hook for 10 minutes from people calling to find out why they were seeing color on their B&W sets!
Cliff
Old 05-25-2006, 12:03 AM
Keefla Keefla is offline
Cliff
How would that work? Im very intrigued right now.
Old 05-25-2006, 12:17 AM
Keefla:
It is called subjective color. It is psychological phenomenon that is typically demonstrated by spinning a white disk with black concentric circles printed on it. When viewing the spinning disk one typically perceives various colors. It is not really understood how it works. One theory is that by triggering the cones in the retina at a certain rate it fools the brain into perceiving color.
Steve
Old 05-25-2006, 08:35 AM
Steve McVoy's Avatar
Here is some information on Butterfield:
http://www.earlytelevision.org/butterfield.html
Old 05-25-2006, 09:00 AM
The color adapter that Admiral planned to build had to be similar to the one CBS made:
http://www.earlytelevision.org/cbs_color_converter.html
Take a look at the schematic to see how simple it was.
The 4 pins on the connector in the Admiral receiver were for vertical sync, video, B+ and ground. The vertical sync was used to drive a phase comparator that controlled the speed of the motor that drove the wheel; the video was used because an extra pulse was transmitted in the red fields, and this pulse was extracted to lock the wheel in the proper phase (otherwise it could lock on any of three phases. The CBS converter and John Folsom's RX-41 receiver -
http://www.earlytelevision.org/field...rototypes.html
- don't have this feature, and you have to manually lock it to the proper color phase)
Our Gray Research monitor does have the feature:
http://www.earlytelevision.org/gray_monitor.html
The other change that was required in the receiver was the horizontal scan rate, which had to be 29,160 Hz, and the vertical scan rate, which had to be 144 Hz for color. The 4 pin connector on the Admiral doesn't provide a way to do this, so it is a mystery to me how this would have worked.
Admiral published a brochure showing their converter
http://www.earlytelevision.org/cbs_c...s.html#admiral
which does appear to change the scan rates, but it couldn't have used the 4 pin connector on their sets.
Old 05-26-2006, 06:28 PM
'The next step...?
Subject Admiral Model 17K12, Chassis 14E76-2 has been called “early analog vaporware!” for a lack of hard-wiring to its color adapter connector. I've add my current thoughts regarding options for the future of this set to my site. For new stuff added to this link, scroll down to 'The next step...?':
http://home.att.net/~pldexnis/potpou...e_Admiral.html
Comments solicited and gleefully accepted.
Old 05-31-2006, 12:40 PM
Here is the Popular Electronics article about Butterfield color:
http://www.earlytelevision.org/butterfield.html#pe
Old 05-31-2006, 02:40 PM
Because of the requirement to run at NTSC field rates, the Butterfield color produced the worst possible flicker rate - 5 Hz. The eye is most sensitive to luminance flicker at about 5 or 6 Hz. Fechner wheels I have seen seem to produce color well at higher rates where the flicker is not so bad, so using this technique with a modified TV system at higher rate might work well.
