Old 04-21-2025, 05:22 PM
The ringing is probably due to a mistuned IF coil, perhaps a sound trap that's tuned somewhere in the video band instead of at sound frequency. No way of telling for sure what it is without the proper alignment gear.
Old 04-21-2025, 05:53 PM
MRX37 MRX37 is offline
Given I had to adjust pretty much EVERY tuning slug in the IF section because I had to replace 2 that crumbled...
But, which one would be the cause? L304? The 4.5 trap? Something in the audio section?
Old 04-21-2025, 08:54 PM
I could not, would not, make a guess. The real answer is to get the necessary test gear and do it right.
However, if you promise not to blame anyone but yourself if it gets worse, you could try more very slow random adjustments, and see if there's one that strongly affects the ringing.
Edit: not anything in the audio section.
Old 04-22-2025, 09:54 AM
vol.2's Avatar
vol.2 vol.2 is offline
Just for my own edification, what is the proper test equipment (other than a scope and a multimeter)?
Old 04-22-2025, 11:40 AM
You could check out Shango066 on Youtube. he's done videos on IF alignment.
What I might do, some day is mark where the 4.5 trap is set at, and try adjusting just *that* coil and see what happens. My suspicion is the 4.5 trap is adjusted into the audio band.
Old 04-22-2025, 12:03 PM
A sweep/marker generator.
