Very nice, Bob!
Hopefully you'll be able to do your magic on the damaged speaker cloth?? I know some will gag when I suggest this, but I've used a little dish soap and water, with a soft brush to clean the insides of the cabinets. just a quick job and dry it off. Never had it harm anything, and the results are amazing. Clean and fresh smelling. |
Unfortunately, the fabric is torn and distressed. Short of replacing I don't there is much I can do.
![]() Meanwhile, I primed and painted the screen bezel with some metallic aged brass I had handy. This set had been a rental for plays and such and abused. ![]() ![]() Fairly close to the original. Maybe bronze would be better? Either way, I'll paint the control doors to match.
Thanks. Found the same pattern in a smaller size from a domestic supplier. Should be here next week.
If it looks good and is proper speaker grille cloth please post the source. My porthole (and I suspect several other models) uses it and mine is just as torn up as yours.
| Audiokarma |
I got it here. Diamonds run the wrong way, but it's just tall enough to rotate 90 degrees and fit.
https://www.ebay.com/itm/375306979157 |
Ever check auto parts stores for touch-up paint?
No, but I should. Seems like 'champaign' would be a good match. The control doors are in better condition than I thought and I will not be painting them. I'll try to bring one with me to a store and find a better match.
Some of the auto parts stores can scan a sample and mix a custom matching rattle can the same way a hardware store will make you a gallon of latex to match a decades old chip from your house...
| Audiokarma |
| Audiokarma |
