Old 12-01-2016, 02:26 PM
DavGoodlin's Avatar
Motorola Minion
Originally Posted by kvflyer View Post
FYI, I have a Photobucket account. It is now rubbish, full of delays, popups, begging for money etc. Many times I just cannot even use it.
Just sayn' (but I guess I get what I am payn' for...)
My flickr account is bit flaky - I log on several different PC's. At work it acts one way, at home another, the laptop still another, and on the phone its very hard to deal with.
Flickr its great for posting numerous pictures of a restore and makes sense when you have lots of photos, instead of one-off posts like this, where it is kludgy to use.
-Dave G
Old 12-01-2016, 02:46 PM
Flickr acts the same on all my devices....VK's upload/image size limits prevent me from uploading %99.8 percent of the pictures I have, and a hosting site has proved easier for me to implement/use than resizing my images and hosting them on VK.
It is a bit less clunky if you run adblock plus in your browser (I still get popups occasionally). My photobucket account is effectively dead to me....Once I (rapidly) ran out of storage capacity and they started prompting me to buy more, I switched to flickr and have not looked back....Well I do occasionally go there to post an old photo still on the bucket.
Old 12-01-2016, 09:14 PM
Call me late to the party, but Dad's (incomplete) Sams for the CTC11 is marked up pretty good. There's this (not in Dad's handwriting) - HOT cherries, check Osc tube filament for 6V. Was half. No corrective action listed.
And plenty about contrast, swapping guns to check CRT, and other non-germane stuff.
PF Reporter also had an instance...
http://www.americanradiohistory.com/...rch=%226dq5%22
Me, no experience earlier than a CTC12, so no real help beyond that note..
USN RET 22YRS (Avionics/Cal)
Old 12-01-2016, 09:39 PM
Gotta wonder at this point if either of the windings might have shorted turn(s), dragging down the Q enough to keep the oscillator from starting.
Old 12-02-2016, 05:29 PM
miniman82's Avatar
First Light: 1952-2011
All the horizontal circuits were mostly the same, even a 16 is easy to troubleshoot with a CTC-9 schematic if you know what to look for.
Evolution...
Old 12-03-2016, 03:24 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Ed stopped by. I think we nailed it. He said that the horizontal diodes are leaky. Since they're mounted on the vertical board, I didn't even think of it.....but I had a feeling that it was a garbage in/garbage out situation.
He said to replace them with germanium diodes. Any suggestions?
Old 12-03-2016, 08:26 PM
I've seen standard 1N4007s work fine as horizontal AFC diodes...I'd try those first if you've got em.
Old 12-03-2016, 08:53 PM
Just curious , while the AFC dual diode can definitely cause loss of H sync, how would it being 'leaky' prevent the osc from running?
Not tryin' to be a smart arse, just thinking it could be a fault condition I never ran into before.
Old 12-04-2016, 08:30 AM
Tom9589 Tom9589 is offline
The actual AFC diodes are selenium according to SAMS. I don't know what the effect would be if you used a different type of diode. Most notably would be the forward junction voltage: germanium - 0.3V; silicon - 0.7V; selenium - 0.95V. I suspect that leaky AFC diodes might cause the first stage of the 6CG7 to drive the oscillator way off frequency to the point of shutting down the oscillator.
Of all the AFC diodes I replaced, the only problem I observed was lousy AFC operation, never an oscillator shutdown.
Old 12-04-2016, 09:03 AM
Kamakiri's Avatar
Not sure. You're totally correct in what you're saying, because my experience is the same. We were triaging this and my 5....he had the 11 chassis on the bench.
Honestly not quite sure, but it's a direction to go in.
I spied this on ebay, so I said what the heck, let's do this instead:
http://www.ebay.com/itm/262744695681...%3AMEBIDX%3AIT
Old 01-09-2017, 09:07 AM
Kamakiri's Avatar
Well, obviously that wasn't it.....but here's where I'm at now.
Traced the issue to PW600. I have both the +275V and the +386V voltages, but I still have no -57V. Board's been recapped. I replaced two of the resistors to no avail.
I still have a couple yet to check, but since those are values that I don't stock, I figure I might as well order the disc caps as well just to cover all bases. What voltage should I get? Or, should I even bother with the discs?
Ed and I worked on this chassis for at least a couple hours weekend before last. We're both scratching our heads.....
Old 01-09-2017, 09:45 AM
DavGoodlin's Avatar
Motorola Minion
Ok this is going out on a limb, but tube sockets have been failing* while looking otherwise intact on recent repairstry the 6CG7 socket, it may have a conductive dust path underneath. Trace those hold coil wires too. I don't have Sams 550 but the resistance table for all the 6CG7 pins needs to be checked.
*Both CTC16 color demodulator 6GU7 sockets and a 12BY7 in the second set could not be helped with deoxit or new tubes.
-Dave G
Old 01-09-2017, 12:16 PM
Do you have the 24 v and 260v on the plates of V601? This would show if the tube is drawing current.
Since the -57v is developed by rectification of the horizontal drive pulse, I imagine its absence only means there are no H drive pulses.
Do you have an oscilloscope? A quick check around V601 would show if the oscillator is running at all.
Old 01-09-2017, 01:19 PM
Kamakiri's Avatar
Working backwards in my mind from over a week ago (been a rough week with my wife coming home from rehab), I remember that the oscillator isn't running at all. We checked and re-checked board traces, tube pin continuity, and grounds.
As I understand it, the +275V and the +386V voltages show that everything going into the board is fine. Once again I'm stymied because there are only so many parts here....
Old 01-09-2017, 01:20 PM
Kamakiri's Avatar
Conductive dust path. Hm. That'd be a new one, but it would also make perfect sense.
