Old 11-14-2015, 10:57 PM
rca2000's Avatar
rca2000 rca2000 is offline
By"control" I mean it gives the chroma it's LIGHT and DARK information, allowing it to accurately produce the correct shades of color. Without the luma...you get ONLY blotches of color info, that does NOT look anywhere useable...
And YES...make sure the service switch, if any, is not dirty, or has NOT been accidently placed "midway", or broken off.
Old 11-14-2015, 11:32 PM
Also look for bad video amp tubes in the luma chain, and if you have a scope check the waveforms/amplitudes in that chain.
Old 11-16-2015, 09:35 PM
maxm's Avatar
maxm maxm is offline
Surrounded by old stuff
I cleaned the service switch, that seems to have corrected the color issue, glad it was something simple, I should have done that at the beginning. I replaced two electrolytics in the vertical that stabilized the vertical and let me fill the screen. I now have a pretty good color picture (photo did not come out well).
Old 11-17-2015, 09:43 AM
That actually looks pretty darn good & close to how
they looked in the olden days. Well done
Old 11-17-2015, 09:58 AM
Hotlips looks good! Great job!
USN RET 22YRS (Avionics/Cal)
Old 11-17-2015, 03:52 PM
DavGoodlin's Avatar
Motorola Minion
These sets were not rare at one time. I recall working on a few at the Admiral-Zenith store where I bench'ed during tech-school in 82-83. But I had seen some K10's for the first time in 1979 and it was quite an introduction
This little Admiral set was used in a troubleshooting contest I entered in 10th grade Vo-tech.
I won the VICA (vocational-industrial club of America) regionals in suburban Philadelphia (thanks to a 1966 Philco color - just like one I had at home , which had an open color bandpass transformer), and the state competitions were held at a "convention/resort" venue just 2 miles from where I now live. I still relive that day when I drive by. I placed 3rd among 8 - BTW.
There were about 8 stations set up with "troubles" introduced into each Admiral. Each chassis was pulled out, cabling extended and mounted on a piece of particle board fastened to the cabinet bottom, hinged so it could be tilted up for voltage checks, etc. Due to my relative unfamiliarity I choked on about half without noting the bad component. It was really simple since tubes were all assumed good and it was impossible to "spot" a fresh solder joint, etc.
-Dave G
Old 11-17-2015, 05:10 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
I recall that scene... he just got done giving her a shot and admiring her butt
SR
