Old 02-02-2015, 10:42 PM
YamahaFreak's Avatar
<-- CSXT 6038, EMD GP40-2
LG 50PC5D YSUS/ZSUS Issues
I have acquired this TV from a neighbor, whom said it did the 'pop of death', and now it works without a picture. I looked up info online and apparently the Y-Sustain and/or Z-Sustain boards like to fail in a manner that necessitates replacement of the whole board. I tried feeling the heat sinks to see if they're getting warm, and it appears that perhaps one of the two on the YSUS board isn't as hot as the others. What I'd like to know is if there's a more accurate way to know which of the two boards (hopefully not both!) are failed. The TV has run for several hours now without issues, other than no picture, obviously.
Sony Trinitron Fan
Old 02-04-2015, 12:16 AM
drussell drussell is offline
If it is one of the models with IPMs, they often fail but I've successfully replaced just the IPM instead of the whole board. A blown IPM will generally fail shorted so will blow a fuse, usually a 4A ceramic 5x20mm, so check fuses first on the Y-Sus and Z-Sus boards. If one has blown, check for a short on that board, typically Vs to ground is what shorts due to a blown FET/IGBT. If this model uses IPMs, the blown FETs will likely be inside the hybrid module, requiring replacement (though some people have bodged on new external FETs ). It's a straightforward task with some solder wick and a decent iron, though a desoldering station is quicker.
If the fuses are all good (look for surface mount ones, too), move on to standard plasma troubleshooting... Check your high voltages... The Vs and Va testpoints are usually on the power supply board and the other voltages on the LGs are usually called things like -Vy on the Y-Sus and and Vzb on the Z-Sus board in LG parlance.
The proper voltages will be on the panel sticker and, IIRC, the second line on the LG stickers below where it calls out the Va (the address voltage for the X boards at the bottom) and Vs (the sustain voltage that does most of the power, comes out the Y-Sus board through the Y-Drives) goes in this order: Set-Up / -Vy / Vsc / Ve / Vzb
Some of these will probably be missing and say N.A. on the sticker as most LG sets do not have all of these voltages but they have maintained the sticker format. Just look for the test points for each and see what voltages you actually have at the testpoints, then I can point you in the right direction for troubleshooting that section.
Vs and Va may only come up for a few seconds at power-on if it senses a fault and goes into protection but you should have time to measure them. A MAX function if your multimeter has one can be helpful.
The service manual is avilable at:
http://www.toms-service-manuals.com/...&mfg=LG-Zenith
Old 02-04-2015, 12:58 AM
Thanks very much, Drussell! I have tested all fuses on all boards (including one each surface mounts I found on the Y and Z boards), and all test good. Now, I am having difficulty locating the test points on the power supply. I'm used to them having 'TP' prefixes, and I'm not seeing anything like that.
Sony Trinitron Fan
Old 02-04-2015, 01:22 AM
I've never worked on this model so I can't say for sure, but taking a quick look at the service manual there are several different possible power supplies and, indeed, it looks like there aren't test points for the Vs and Va. You're supposed to just stick your probe into the back of the output connector. (There should be a silk-screened legend beside the connector.) Your negative multimeter probe can just go to any convenient chassis metal like one of the wallmount holes as the chassis is at circuit ground potential. Vsc/Vscan is usually one of the only ones that you measure across a resistor or capacitor rather than to ground as it is floating.
If you have a decent camera, perhaps you could post a couple good close-up pictures of the various boards and one of the whole back of the TV so I can see what we're dealing with and how everything is interconnected.
Old 02-04-2015, 03:43 PM
I've got the service manual - lemmed klnow if you need it - FREE. Don't pay for it - LG gave it away for free for over 2 years, and then took them off the web. I have a little over 300 LG LCD/plasma/DLP and Zenith CRT sets data, all free from the old LG FTP site.
The manual for the 50PC5D is over 30 megs in size, so a high-speed (DSL/Cable) connection will be needed. I don't have a server, but may be able to upload it to a church website I manage.
PM me if interested.
USN RET 22YRS (Avionics/Cal)
Old 02-04-2015, 04:15 PM
That will be most helpful! I'll get in touch.
Sony Trinitron Fan
Old 02-04-2015, 04:26 PM
That link I posted above has the service manual and it's free... Though perhaps you have a better one, this one certainly doesn't cover everything.
Perhaps you guys missed the link in my first post?
Old 02-04-2015, 03:44 PM
I'll see what I can do with this iPhone, though unfortunately it only allows me to add one photo per post. My power supply's part number is (I think) 2300KEG006C-F. I've attached a photo of the upper left connector, showing the silkscreened voltages. (The connector is unplugged in the photo, for better visibility.)
Sony Trinitron Fan
Old 02-04-2015, 03:46 PM
Here is a photo of the entire chassis. YSUS at left, power supply in the center, ZSUS at right.
Sony Trinitron Fan
Old 02-28-2015, 07:29 PM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
It's been a couple years since I worked on one of those models. But if my memory serves me correctly, there are a couple pots on the Y/Z boards that you can tweak to fix the "sparkles". Seems like one of the main ones was labeled "Vscan" or something similar. I am sure there is a "correct" way to do it with a meter, but I always just did it hot and eye-balled it. Maybe somebody who has worked on one more recently can jump in with more up-to-date info.
Old 02-28-2015, 08:24 PM
That's actually pretty much exactly what I did, after some reading up. One of the two pots under the heat sinks on the Y-board was able to clear up the 'red snow', but I still have some 'sparkling' or mostly white flecks in the screen when there's no picture. (i.e. black screen) Not noticeable with a picture on the screen, so far. I didn't adjust any pots very far, and put all but that one back where they were, as I was morbidly afraid of popping my new IPMs or worse!
Sony Trinitron Fan
