Old 02-25-2013, 05:11 PM
holmesuser01's Avatar
I've got a bunch of B/W 8mm stuff that came from the collection of another film guy I knew. All straight porn.
On 2 1200' 8mm reels. Not for sale.
Old 02-25-2013, 07:55 PM
earlyfilm's Avatar
Eternal Member
Originally Posted by leadlike View Post
You can have your films processed by Alpha Cine in Seattle, Wa. There are others, probably with slightly better rates, but I have had good results with them. There are home processing tanks for B&W reversal, but the cost of chemistry alone is enough to leave processing to the pros.
You better check before sending B&W reversal to any US lab. Most Labs quit processing B&W reversal when the EPA banned one of the chemicals in the "chemical flash" that is used only in the B&W reversal process.
Most Labs thought there was not enough work left to afford to convert their processors back to the more time consuming optical flash method. Nice chemicals like this are why we were known as Lab Rats, and why you rarely see an old one. On the latter, I guess I'm an exception.
It has been years since I used Alpha Cine for film that I could not handle. I have no idea how they are now, but they used to do extremely good work.
Also, ONLY buy your film direct from Kodak!!! I see so many folks buying films from online shops, when all you have to do is call 1(800)621-film. That is Kodak's direct ordering line, where you can order all your super 8, 16 and 35mm for as cheap as it gets.
It sure is news to me!
How long has it been since you did this? Kodak plainly says on their web site that they only sell to dealers, and to check your local dealers.
I've never seen a 300 ft reel before, so you likely either have films on 200 ft spools (typical) or "ultra deluxe" 400 ft spools.
And, yes, I see that I completely forgot the deceptive reel size introduced during the early 1960's.
8mm Reel sizes:
50 ft = 3 inches
100 ft = 3 & 1/2
200 ft = 4 inches home reel
200 ft = 5 inches, for commercial releases, with larger and heavier plastic reel with an oversized hub to fool the public into thinking they were getting more film when judged by the size of the box. These first appeared in the early 1960's.
300 ft reel = 5 inch diamater with a .75 to 1.5 inch hub, from the late 1930's & 1940's and are quite rare. These allowed people with the older 8mm projectors with short reel arms to run longer films than the machines were intended to take. These hold 250 feet with ease, as shown, but without the smallest hub, 300 feet may be a bit close. The original owner of these films remounted them from the standard 50 foot Kodak processing reels about 1945.
400 ft = 7 inches
800 ft and 1200 ft. Modified 16mm reels, with a half width center. These are extremely rare on 8mm. Projectors that will handle them are also rare.
James
Old 02-27-2013, 10:14 AM
init4fun's Avatar
init4fun init4fun is offline
Hi Earlyfilm ,
Thank You for the reply . In the photo I put up in a past post here it does look like two of the reels have larger hubs than the other three , and I can readily see where those two have less film on them . (something I never noticed looking at them till you mentioned it . Thank You for that insight) Since they are all 5" at the outside and differing diameters on the inside would it be safe to say that 2 of these are 200' and that 3 of them are 300' ?
Old 03-14-2013, 08:31 AM
init4fun's Avatar
XXX films are gone , and the Hobby remains :)
I figured I owed this thread a post regarding the final resolution of the films . A nice collector was happy to add them to his collection and in return I got some great G rated material to demonstrate the projector with . I display my old projectors alongside my old radios and every so often I get the "Do they still work ?" question , to which I now can say "Sure , wanna see one run?" rather than "OOps , I've got no film to run through it"
Happy Collecting one and all , and Thank You again for all the responses to this thread
Old 03-16-2013, 01:24 AM
Thank you for the update.
