Well it sorta woke up. when I tested it a couple of hours ago all three guns were testing bad. I immediatly resetup the tester and the blue tested about where the others were, but the other two still tested bad. the only way I can get a dim raster with the sun shining on it as it is now is to turn the brightness all the way up, the only screen control allthe way down, and the drives all the way up.
The drive controls are where the sparking is coming from. The HV no longer drops so the tube emmisions are probably low(that or the HV fixed it self and my tester is bad). gota go. Tom C. |
Shouldn't the screen controls be up as well? If you reduce the screens, the guns will emit less electrons and of course it will be dim. Are drives the same as background? Quote:
Bad pots?
Evolution... |
I today left the remote in the care of the local batteries+ franchise so hopefully within the next week they will have either tracked down or made a electricaly and mechanically equivalent replacement for the out of production original.
Tom C. |
Well the sam's arrived from banderson today (thanks!), and it definitly uses a wierd CRT set up procedure(compared to the Zeniths and RCA clones I'm used to) the cathode levels are set by pluging the wires that come from the socket into several terminals rather than by potentiometers. The RGB background controls(miniman had the name right first) adjust the grid bias, and a single "master screen" controls the the three screens the leads of which are conected together just after leaveing the socket.
When I get the chance I'll attempt the grayscale procedure, and see if I can get a good picture. Tom C. |
