Old 03-09-2011, 03:40 PM
Rca?
http://orlando.craigslist.org/atq/2220903462.html
Picking this up today, free so I guess is better me than the scrappers
Old 03-09-2011, 04:02 PM
That looks like a delta gun CTC8x or 9x chassis from the late '70's. It could also be an inline gun CTC10x chassis from the early '80's, since the design didn't change much during the late '70's-early '80's. I don't think it's old enoough to have the upright CTC68 chassis in it.
At any rate, if the CRT is good, it should make a nice picture.
Old 03-09-2011, 04:06 PM
I am mainly just getting it for parts, I really don't have room for it, but I know its fate if it goes to the street...
I am hoping for a decent 25v delta gun.
Old 03-09-2011, 05:45 PM
Don't expect too much out of that tube, unless it's been replaced sometime in the sets life. Those "late" delta gun RCA tubes from '77-'80 didn't hold up that well. I saw plenty of these sets, when they were younger, with weak and/or shorted CRT's. And, rejuvenation didn't always help. At present, I have a 19" RCA delta gun colortrak from '79 that got a new CRT when it was less than a year old.
Old 03-09-2011, 06:18 PM
here it is. The CRT is a delta gun, the CTC number is rubbed off, all the guns tested ok, but the Blue setting had a much different cutoff, and it did not track well on that gun. I dont know that I want to mess with this.
there is a fuse and its ok, the degausser works, but thats it. I can hear a rapid ticking coming from the side where the fly is, beside that and the dial light coming on I get no sign of life.
oh the CRT is a 25vCZP22
Old 03-09-2011, 07:33 PM
sampson159's Avatar
sampson159
late 70s colotrak?decent sets bit not as good as the earlier xl100s and the fold down chassis colortraks.seems crts went south on these sets.they will take a jolt periodically though.there is a diode in the power supply i can remember that was a problem.same characteristics of your set.good luck with this and i have a good crt if you need it
Old 03-09-2011, 07:35 PM
well for fun I checked the HOT, seems ok (.4v diode mode BC,BE nothign CE.
I will look around for that diode
Old 03-09-2011, 07:48 PM
from what I can tell the AC interlock connects to a board with a fuse, thru the degausser, then a bridge rectifier, I get lost after that. But there is this odd looking can, looks like a small can cap, about 3/4 wided and tall, has 3 thick metal legs. I dont think its a cap, just a guess but some kind of relay in a can?
Old 03-10-2011, 09:31 PM
ctc17 ctc17 is offline
ECG238 man that rings a bell...The 6JE6 of horz transistors.. That was the part that would break the set and send it to the curb when I was working on these sets in the 90s. That cost like $9 and lots of people would say trash the set when you told them there was a chance something else could be wrong that caused it to fail.
Old 03-10-2011, 11:45 PM
you have to read the regulated B+ while it's running. Place the neg lead of the meter to Hot ground and positive lead on regulated B+
Old 03-11-2011, 08:47 AM
there were some test point on one of the boards,(the one in front of the defection board) 21v 27v and 11v
they were very close (+-.5v if i recall correctly). I will check again for exact numberrs and scope as well for ripple.
It ran for hours last night with not issue. I take it the startup is where the problem presents?
Old 03-11-2011, 11:11 AM
turned it on this am, came right on.
Got the rifleman on now (B&W), grey scale looks very nice. These set's make a very nice pic.
Old 03-11-2011, 11:17 AM
Just curious, I see on the regulator board the warning about not fixing but replacing. Anybody know what the deal was with that?, I dont see any parts that look special, unless there is something special about some of the transisotors. I did not look to see the PN's on them.
Old 03-11-2011, 01:13 PM
airgrabber-6's Avatar
airgrabber-6 airgrabber-6 is offline
Avoiding electrocution.
Are you still planning to deliver it back to the original owner?
current victim:
"Blondie"...a '62 Magnavox 27" Normandy Provincial
Old 03-11-2011, 01:17 PM
They dont want it, just glad it went to a good home. I wish they would as I dont have room for it as is.
I tested the voltages
27=26.73
22=22.08
11.8=12.38
there was a 210 but it tested at 20.92 so maybe that was a 21, maybe I was misreading the board.
on a different board I found another 210 it was 200vdc
