Old 11-17-2012, 03:11 PM
Originally Posted by Penthode View Post
However, the benefit of Apex over all other boxes is that it was the only box I could find which allows you (from the S Video) to extract the luminance (black and white) signal without the interleaved chroma. This is especially important with early sets employing full bandwidth 4 MHz response like my late '40's RCA sets. It means that the black and white image will not have the crawling dots: its just like going back to the old fully black and white days!
The Channel Master box also has S video. And I use the luma portion for my B&W sets as described above. I modified my Channel Master CM7000 to produce B&W without chroma from its RF modulator:
Here I made the chroma switchable, so I can have color or B&W as I want.
Old 11-17-2012, 03:56 PM
Spinning Head Spinning Head is offline
I have both the Zenith DTT900 and DTT901 boxes. I've noticed a common problem with the DTT901 boxes is that when cold, often times the box will turn off after being turned on. (Power light goes blue, than goes back to red). On extreme occassions the box locks up and needs to be unplugged to reboot it. With the weather get colder, this has been happening more frequently. Has anyone else observed this with the DTT901 boxes?
