Old 06-04-2008, 06:59 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Is it the power supply that gets mighty hot? Or the tuner/RF modulator?
If the PS, then there's several reasons now to use an outboard power supply.
1) it runs cooler.
2) it runs less noisy (RF interference on Ch3 on older sets)
3) it runs less noisy (spikes hard on internal components)
4) it could run on battery!
5) it's a reason to get out the soldering gun and play.
Especially bullet 4, I'd like to modify one to run on NiCad pack or car battery for use with a battery-powered TV during outages.
Except of course if the outage is caused by a storm, in which case the digital signal will probably block and drop anyway, so it would be moot.
Do not attempt to adjust your set.
Old 06-04-2008, 09:10 PM
jhal's Avatar
jhal jhal is offline
Titanium bliss
1) it runs cooler.
#4 is a very good idea! I will have to open up one of mine when I get it to see how easy (or hard) it would be to add a DC jack and a switch to choose between internal and external p/s's.
JBL XPL-200A's biamped on Yam. PC2602M & M-2 amps with
Ashly XR1001 xover, Yam. CX-830 preamp,
ADC Sound Shaper 2 EQ, Yam. Q-2031 EQ
Yam. DX-350 tuner, Tech. SL-1400 turntable,
Yam. CDX-900U cd, Pan. DVD-RP56 dvd,
Den. DRR-780 tape, Sony SLV-575UC vcr
Old 06-04-2008, 10:52 PM
OvenMaster's Avatar
DTV blows
1) it runs cooler.
From what little I've been able to see, it's possibly some of the digital circuitry that causes the heat! One time I'd left the converter on a blank subchannel overnight, and when I went to pick up the remote in the morning (I park the remote on top of the box) the box was barely more than room temperature.
Tom
Tom
Old 06-04-2008, 10:55 PM
Chad Hauris's Avatar
Doug, can you see what the failure mode was and if an external supply can be rigged up for them. I really depend on the converter boxes to get a good quality TV signal and would like to keep them going...hopefully its not a case like on some DVD players I've heard of where there is no overvoltage protection and a power supply failure burns out chips on the board.
Chad Hauris
Old 06-04-2008, 10:58 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
You could cut a hole in the top of the case and install a small computer fan to help with cooling.
Old 06-04-2008, 11:02 PM
I got some DTV coupons I haven't used yet so I think I'll get a second insignia and measure the voltages from the power supply in a normal condition...that way I may be able to hook up an external supply and know what voltages I'll need.
Chad Hauris
Old 06-04-2008, 10:42 PM
fsjonsey's Avatar
Well,
I'm the first to have the first DTV converter box failure, or atleast the first to report a failure on AK. I have the zenith converter box which is sold at circuit city, which is the same as the insignia box sold at best buy. While watching TV this evening with the box, the screen all of a sudden went into intermittent blue horizontal bars and then the unit shut off. I attempted to turn it back on and nothing. The red LED which is on when the unit is switched off even went out so its dead as a door nail now. No reset button on the unit. Wont respond to anything, remote or at the unit. Perhaps something in the power supply failed. Ive yet to investigate. Too late to get into that now. All I can say is that this is pretty poor. Ive only had the box about 1.5 months and it broke already. Im curious if more will fail as time passes in the near future.
This digital transition is a joke. More BS to deal with. Cheap crap converter box is an insult to the Zenith name. I think the quality fell out before the name went on with this thing. Whats next.
Did the box get hot when it was still working? The poorly ventilated enclosures so common on modern electronics often cause SMD components to unsolder themselves from the boards. I've had similar problems with multiple wireless routers in the past few years.
Old 06-05-2008, 02:21 PM
Git-er-done!
Old 06-05-2008, 09:29 PM
You could also try some freeze spray to locate thermal defects.
Old 06-07-2008, 08:00 AM
Well,
I have the insignia ns-dxa1 box and so far so good. Took a look in the manual and it has a 90 day warranty so you may want to check that out.
Fun wow, Now we are going to have to fix the new junk to keep our old junk running.
Ed
Old 06-07-2008, 12:09 PM
jhal's Avatar
Titanium bliss
I bought four of the Insignia'a yesterday, 2 for me, and two to setup for my grandmother. I haven't messed with them yet, though I did take one out to look at it. It only requires 7 watts, so it could be run off of an inverter and jumper pack along with my battery TV that has composite inputs. Should be good for a couple of hours at least since I have a rather large jumper pack.
Still, that's quite a mess of wires and setup time just to watch the weather during a bad storm. I do have a 20kw genny, so it would only be needed if it failed or ran out of diesel.
Old 06-07-2008, 09:43 PM
kbmuri's Avatar
I received my Winegard RC-DT09 from SolidSignal (a month late, but finally). I have to say I like it maybe best of all. And also, the power supply is outboard already! Just a small 9VDC wall transformer with a typical power-supply jack on the back of the converter box. Real easy to make a 9V NiMH cell pack or maybe just stack a few 9V duracells in parallel for that emergency tornado-warning use. No mods to the box or P/S whatsoever, just buy a new jack from Rat Shack and go.
User menus are comparable to the Insignias or Magnavoxes, reception sensitivity looks the same too. Plastic case is a little cheap, but like a lot of the others in that respect. Physically smallest in size (width anyway). Tiny remote, but gets the job done.
I like it.
Old 06-07-2008, 11:03 PM
I like it.
That's very good to know. Here in East Central MS, hurricanes Ivan and Katrina taught us to be prepared for any emergency! We were without power for 12 days following Katrina and we had a 13" color TV plugged into an inverter connected to the cigarette lighter in the car. This Winegard converter should make it easier to use my Panasonic B&W portable.
Old 06-08-2008, 12:53 PM
zenith2134's Avatar
Haha, that pic looks like my room., speaker cones and heatsinks all around...
Cool Sony monitors.
Radiotvnut, that's rough.... Reasons like this are why analog tv should be kept around in some form in an emergency.
Old 06-08-2008, 06:42 PM
kbmuri's Avatar
I wondered if anyone would catch the heat sink. It's a FK660 from here: http://www.futurekit.com/products.ph...3&category=FK6
Sad to say the local distributor for them in Fort Wayne went out of business some time ago (nobody builds stuff anymore). Driving a 15-inch woofer it'll rattle the walls, and I think it was maybe 15 bucks at the time. The Sony monitors are part of a shop project still in the works. They're video only, so I had to patch the DTV-box's audio into a pair of FK660s and some speakers. Just rough-hacked on the floor for testing, a cabinet is planned (woodshop project too) sometime, when time permits.
