#31
I just got the Zenith installed today and now she can actually see the shows and not futz with the antenna to get sound without buzzing. And more channels! So if it looks like there may be concerns if funding runs out it sounds like it is good to get them early. And you can actually enjoy the benefits now. |
#32
So which brand is the best quality box?
McIntosh MC206,MX130,MVP861,RGPC1200,Magnepan Tympanis (1pr.),KEF 104/2's (1pr.),ESS PS8H's (1pr.),McIntosh XR240's(1pr.),Klipsch KLH-10(1 pr.),SilverBullet 4.0(1pr.),White Zombie 1M Silver IC(2pr.),.5 meter Silver IC(1pr),30' Silver Cables w/large spades (3pr.) |
#33
It depends on what is available and features you feel is important.
As we approach Analog Doomsday 2009. I'm sure there will be more reviews. But here's a link to recent consumer reports review of Insignia, Magnavox, Zenith http://www.consumerreports.org/cro/e...first-look.htm |
#34
Thanks terra1!
#35
I picked up an insignia box a couple weeks ago. I am pleased for the most part. However, I get a little intercarrier buzz in the audio, which I do not get on analog OTA stations, nor do I get this on other sources of input (vcr, dvd). Quad and buzz controls have no effect, it is an IF alignment issue. Does any one else experience this?
I use the box on a good working 1970 zenith color set with the solid state IF sub chassis. I havnt looked into it further, but if this is a common problem to all sets of this age, I'll have to touch up the 39.75 trap on all my sets when 2009 comes around. |
| Audiokarma |
#36
I tried my Digitalstream box on a '77 19" XL-100 and I get the buzz. I do not notice the buzz on analog OTA TV.
#37
Either the video level is a little too high on the box, or their RF modulators are poor quality. You might have better luck using an external RF modulator. This would also make it easy to reduce the video level.
#38
I have the Zenith, but I don't get any buzz.
Last night it was raining and I got some intermittant signal loss in the basement tv. Occasional pixelation. I switched to a different antenna but I don't know if that was it or just improvement in the original signal. There was no problem on the upstairs tv. The basement tv does get fewer channels found. When I first set up I noticed on the upper channels the audio sometimes seems out of sync with images - like voices are dubbed, but after awhile it seems to match. And sometimes the digital image seems just a little cold and jerky compared to smoother analog. I can picture it now. People will wax nostalgic about the old days of analog being more tube-like versus digital like LP vs CDs!
#39
As for digital TV, one difference I've noticed is when you have a weak station. On an analog TV, the picture may be fuzzy or have ghosts, but it's always there. Using the digital tuner on my DVD recorder, a weak digital signal may break up (pixellate) or freeze, or drop out completely. The digital signal looks great at other times, of course, but the dropping out part is annoying. On this tuner, it gives you a no-signal message and then you have to grab the remote and push a button to make it try again. I haven't bought a converter box yet (coupons are supposedly in the mail), so I can't vouch for what they do with a weak signal. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
#40
I picked up one of the Insignia boxes over the weekend. {Still haven't got my damn coupons yet}I get a slight buzz but nothing major, only when a really bright white screen is present. I am currently using it on a '67 Zenith 23" with the 20X1C38 chassis. I like the box but I sure will miss the good 'ol analog when it's gone
. I have it hooked to a GIANT Winegard antenna with a 28db on mast booster sitting atop my garage. I also use the antenna with analog too.
My TV page and YouTube channel Kyocera R-661, Yamaha RX-V2200 National Panasonic SA-5800 Sansui 1000a, 1000, SAX-200, 5050, 9090DB, 881, SR-636, SC-3000, AT-20 Pioneer SX-939, ER-420, SM-B201 Motorola SK77W-2Z tube console McIntosh MC2205, C26 |
| Audiokarma |
#41
After the warrenty period is up, crack open the box and see if you can find the video line feeding the modulator, and add some resistance in series, or to ground, to reduce the amplitude a little. But you'd have to be sure that doing that doesn't mess up any DC biasing. A set from the early post war days that uses completely separate sound and video IF strips won't have this problem. But otherwise such a set is hard to tune a TV channel on.
Got my box, a little bit of magnetic field leakage prevents the placement directly on top of my set:
![]() Nothing is ever completely fool proof, because fools are so ingenious. |
#43
The coupons came today! My 'ol lady just called and said they came. Should I get another Insignia or get something else? Any input would be great. I've heard good about the Maggie {Funai} box, but I looked at them and I think they look cheap with their plastic case and power switch instead of a button. The Insignia has the intercarrier buzz but it has a very well made {as far as chineese crap goes} cabinet and remote. Zenith {LG} box maybe?
