Old 02-27-2006, 09:13 AM
kc8adu's Avatar
kc8adu kc8adu is offline
a friend down the road has a similar looking unit packed away from a move.
he got it when whio tossed some stuff in the late 70's
i get to revive it this summer.
i will post pics here too.
would be neat if its the same unit you have.
a foreign unit with an rca jug and yoke bucket.cool.
email for more info
Old 02-28-2006, 08:35 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
These monitors were exported into the U.S. in the 1960's and 1970's. The engineer told me that he was with it on an exhibition in the General electric laboratories, to introduce the monitor. The American engineers were impressed. But after he returned to Germany, he got a message, that this monitor could not sold in the U.S.. The x-ray emission was exorbitant high.
The Germans had no experience with the shunt regulator and the x-ray shielding. They had to insert a piece of sheet metal around the PD500 to lower the x-ray emission. Some of the shunt regulator tubes got so hot that the glass melted.
In the television factory, they had a large hall where they tested the color picture tubes. More than thousand tubes were tested at the same time for shorts inside the tubes. They were driven with 30,000 volts continuously for four weeks, provided by a simple test-chassis with shunt regulator. After the test the tubes were installed into the tv sets. Some of the engineers, which worked with the picture tubes died because of high x-rays in these days.
Old 05-11-2006, 03:21 PM
yagosaga's Avatar
VK Member
I have measured the emission of the crt (RCA 1842P22). On the red gun I measured 0.7 mA, blue and green have 0.5 mA. What do you think, is it OK? My crt meter tells that 0.5 is at the borderline between good and bad.
Eckhard
Old 05-11-2006, 03:34 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
As long as it will make a grayscale picture and the guns aren't bleeding it should be OK.
Jordan
