Old 03-26-2003, 09:48 PM
1966 rca ctc24
I found three really nice tvs in the past 2 days. each spring, our town has "amnesty day" Basically you can through anything away for free of charge or special pick up. Everyone then cleans out their house, so this is where the big tv search begins! I found this nice ctc24 right on my own street! Its in great condition, but have not worked on it yet, blank raster with hv arcing! Its a matter of time before it get it going again. Looks like a replacement crt, its a bonded lens, but not tinted Ive been focusing on fixing up and finding parts for my portacolor recently (another amnesty day find!)
Old 03-31-2003, 07:23 PM
captainmoody's Avatar
captainmoody captainmoody is offline
Here's a picture of my 1967 Zenith, It has been in my uncle's basement since 1987, Finally brought it home today. Found it in the trash the summer of the same year in excellent working condition. Sadly, The cabinet will need a lot of cleaning and touchup, As my nephew used it as a workbench!
Old 04-06-2003, 06:21 PM
here's a pic of the cabinet cleaned up.
Old 04-06-2003, 07:23 PM
Dwight,
That tv looks lots nicer! What did you use on the finish? Ive used Old English on cabinets and it hides the imperfections pretty well. What chassis do you have in there?
Old 04-06-2003, 08:39 PM
20X1C36, I first cleaned the entire cabinet with degreaser, Then used Minwax walnut stain, sealer and finish. All I did was rub it on with a cloth and let dry, Much like old english but lasts longer.
I would rather do that then refinish a cabinet with scratches like those.
Old 04-29-2003, 09:02 PM
Ive got that zenith working great now
Got this nice one from captianmoody which he has a photo of. Here is a pic of it working with proper color and converged! 23XC36. Of course, Green halo must ruin a nice picture on any zenith
Just got it converged! Followed zeniths guidelines as to proper converging. To my surprize, excellent results!
Old 04-29-2003, 09:06 PM
1967 table model
How often to you find these? 25" zenith table, all steel cabinet. This one has a toasted crt. Has a million hours on it, but does not show it cosmetically. Looks like it has a lot of potential if I can find a good 25GP22. Anyone have a set of tuning knobs like the ones on this set? I stole the knobs off my console and am convicned they are the correct knob as this set has the back light tuning and same styling as my console.
Old 05-23-2003, 10:43 PM
I found this Magnavox next to a dumpster today. It works, but has some vertival compression at the bottom and the picture is unstable (probably dirty controls and bad soldering). It uses a 22JP22 CRT which looks bright and sharp. It looks like it was made in the late 60's. It's model 1C6304 which isn't listed in the SAMS index and I don't see a chassis number anywhere. It's 100% tubes apart from the UHF tuner.
Old 05-28-2003, 02:31 PM
Nice Magnavox Andy! Looks like a 1967 or 1968 model to me.
I picked up another Zenith from my ad today, 25NC38, 1967 model. This one is real clean and has a replacement Zenith tube in it also, Oddly it has the beginnings of pva deterioration (not that bad yet) but like an RCA tube not the familiar halo that it seems all zenith tubes get.
The original owner repaired it himself and left notes inside it, Kinda creepy cause he died a few years ago, One of them said: Hope you get as many years use out of this as I did! The others were where to get parts, And what parts failed most often!
I have never in my 25 years as a tech seen anything like this! Looks like I will restore it this summer as it was a well cared for tv.
Also was given a B&K 415 Sweep marker generator in mint cond along with the tv, And the best part was they were free!
His wife was real nice and just wanted to find someone who would enjoy the stuff, Heck yes! I was going to bid on a 415 on ebay today to go with my 1077B, Now I won't have to....
Old 05-28-2003, 06:00 PM
You guys are really tempting me to try the news ad! I am scared that I will get a truck load in my basement and I will not have a clue what to do!
Old 05-28-2003, 06:18 PM
wiseguy wiseguy is offline
25GP22 replacement on e-bay
here,this crt is supose to replace a lot.
http://cgi.ebay.com/ws/eBayISAPI.dll...2&category=298
terry
Old 05-28-2003, 06:37 PM
Thanks wiseguy! one finally showed up!
Old 05-29-2003, 06:47 AM
Chad Hauris's Avatar
I have a 1968 Zenith at home that has a 23V" color CRT that was bad, and that had the mounting hardware permanently attatched to it. This created a problem for replacing it with a salvaged 25XP22 RCA tube (the RCA has detachable mounting hardware that attaches in slightly different places.) I had to drill holes in the CRT mask in the cabinet to attach the mounting bolts, and the new CRT sits slightly back in the cabinet--there is a gap between the faceplate and the mask.
This is something you will want to watch out for in the Zenith. Also, if you buy a brand new (NOS) RCA CRT and you have a Zenith with the permanently attached mounting bracket around the faceplate, you will have nothing to hook up the new CRT in the cabinet.
Old 05-29-2003, 02:01 PM
The set I gave Doug is a '67 and doesn't have the permanent hardware so he should be safe in bidding on that nos tube.
Sounds like a lot of work you did on that Zenith! I have a '68 and it uses the regular tube with no permanent mounting hardware.
Whenever I run into anything like that, I try not to drill holes or cobble parts from other sets and put them on it, or modify the tv in any way from the norm for safety and or historical purposes, I would wait for the right tube or if that is not possible use the brackets off the old one, some tubes had the mounting tabs welded to a collar that looked like it was cemented on the tube with frit or something similar, I would break or cut the tabs off then weld them to suitable mounts and attach them on the new tube with the rca huge hose clamp hardware!
My main goal when substitution is necessary is NOT to modify the tv so that it looks cobbled or is unsafe, And insure that it can be put back to factory specs when a tube becomes available.
Old 05-30-2003, 07:01 AM
Yes, the repair I did on that Zenith is not something I would recommend and it looks like a real "hillbilly" job with the bolts sticking out from the mask, I did that when I was younger and would not do today. I got the set for $5 and happened to have a 25XP22 from a junked set so I decided to experiment to see if this would work.
