Old 07-02-2005, 02:03 AM
frenchy frenchy is offline
Frenchy
This is probably a dumb question based on lack of knowledge about color combining, but would it be possible to put a slightly tinted film over it of a certain tint like orange, or brown, or yellow or something, like a complimentary color, and it would end up being more of a light brown or at least less green and closer to neutral? Ok, end of dumbness....
Old 07-02-2005, 04:14 AM
David Roper's Avatar
console lover
I think a Purple filter would have the best chance of looking greyish.
tvontheporch.com
Old 07-02-2005, 12:10 PM
Frenchy
Would be interesting if he plays around with this for the heck of it and sees whether, or how much, the green can indeed be un-green-ified! Even if it worked the brightness would go down but who cares, crank it up. Purple huh? Yup like I said it would probably have to be a very light tint, whatever the color, or you will end up just changing it to that color and cutting the brightness even more...Frenchy
Old 07-04-2005, 09:38 AM
The green phosphor is a fairly saturated color, which means it has green, some yellow-green and some blue-green wavelengths, not much else. So you could reduce the brightness and shift it somewhat towards blue or yellow, but not much more unless you made it really dim.
Old 07-16-2005, 08:49 PM
Richard D's Avatar
Richard D Richard D is offline
On Steady-cam mount systems after the camera man puts on the rig over the shoulders and straps it on, he is looking down waist level at VERY bright 4 0r 5 inch monitor with green phosphers so when he is in bright sunlight he can still see what the steady-cam camera sees. The pro models of steady-cams start at $20,000. That was 10 years ago. My 2 cents, Richard.
