Old 12-20-2004, 07:54 PM
Any luck on the '69 Zenith yet? Keepin' my fingers crossed for ya...-Sandy G.
Old 12-21-2004, 02:49 AM
heathkit tv
Guest
Posts: n/a
Originally Posted by Eric H
The vertical shrinkage may adjust out, isn't that the vertical module down in the bottom right corner? the one with the big aluminum heat sink.
Or maybe one of the electrolytic caps is getting tired.
If you only watch letterboxed movies you'll never know the difference
Letterbox indeed! You am correct about that module...according to the diagram inside (on the left) it's number is 9-147
Regarding that '69 set, if I don't hear something by tomorrow then I'll assume it's not gonna happen. Doze bastids!
Anthony
Old 12-21-2004, 05:59 AM
jstout66 jstout66 is offline
Also... if I remember correctly if the vertical module goes bad it can shut down high voltage. I think Zenith tied in the high voltage into that module and nearby fuse. Also when I had a Chromacolor 2 repaired recently there are 2 capsin the high voltage section (on the backside of the chassis) that the repair center wanted to replace. Zenith used to sell them in a kit, I had to get them from Moyers. I had the tripler and those caps changed on my set. I also replaced the vertical and horizontal module. Set works pretty good now, but I have put it into storage and am using my 4 tube hybrid Chromacolor instead. It has a better picture and is not as "glitchy".
