Holy yeah man. Those things can get good and jammed up in there. I've seen people taken them apart to find they were glued or waxed in place before at the factory as well, but I don't know how common that actually is.
Ah, well hello there, you little b******!
Meet L304. The coil that has been giving me no end of trouble. More specifically, meet the iron slug inside L304... which CRUMBLES! INTO! DUST! with every tool I try to use to turn it!! There is no turning that iron slug. It's just breaking apart inside the coil. Okay... You know... I no longer want that slug out of the coil... I've decided it's coming out of that coil! https://images2.imgbox.com/47/30/mWmxfYZU_o.jpg It took multiple Q-tips soaked in rubbing alcohol to get all of it out of there, but it's out of there now. And now I am hunting online for a replacement slug to go into it, because, like i said, I am not going to be beaten by an IF coil. |
Stubbornness mixed with patience and skill can be fun sometimes.
I hope you find a good usable slug. It likely should not be too hard, maybe you can find a variety pack/old pile of coils with slugs and try them until one has the needed effects.
Chris Quote from another forum: "(Antique TV collecting) always seemed to me to be a fringe hobby that only weirdos did." |
I tried sourcing a slug from a pair of those 49Mhz toy walkie talkies (Funny thing, they still cost $10, decades later...) But the slug was too small. Coil might work though, if I were desperate. TV IF is 45 Mhz and toy walkie talkies are 49 Mhz so the coil has to be pretty close. |
Ladies and Gentlemen I found a replacement tuning slug!
https://images2.imgbox.com/bc/99/j8EI6zYR_o.jpg The slug came from an Ebay ad titled ".17 - .25 variable RF inductor vintage PC mount adjustable radio tuning coil NOS" The slug appears to be a 4.35mm slug about half an inch tall. Putting the new slug in and making adjustments to it and the AFT balance pots has certainly improved things: https://images2.imgbox.com/d8/49/LhDti4fF_o.jpg However I am still getting audio crosstalk in the picture, and the audio sounds a little bit strange. The volume is fine, but the Treble, especially S sounds are distorted at any volume. So, definitely better, but it's not all the way there yet. |
| Audiokarma |
Find & adj the 4.5 trap. Put a flag on your stick so you can go back
Zeno
And it took multiple turns to have any effect at all. I'm thinking the slug inside that coil is probably crumbling as well. I tried bottoming it out and my screwdriver just kept turning. I'm thinking if I get another slug and replace it, that might be the whole issue. |
I have an 1983 RCA with same problem with the sound. The TV has a lot of hours on it but it still has a good tube. The tunner muduler was worked on in the early 90s but other than that it looks untouched. I need to get some adjustment tools so I can try adjust the IF can.
Searching this forum has told me that L201 is probably the culprit for sound, if not the 4.5 trap. But I think those powdered iron slugs have degraded over the past 4 decades, and I think that has thrown off the inductance of the coils. When I get time, and more slugs, I plan to replace the slugs in L201 and the 4.5 trap. |
Got several replacement coils with tuning slugs in them today.
Pirate Pete Electronics is the eBay seller, in case you're somebody whose looking for these slugs. So at some point I am going to pull that chassis board, again, desolder the IF shield, again, and replace a tuning slug... again. Oh, did I mention I have little experience with IF alignment, and I don't have a scope? This is going to be FUN!! "Just the fact that you're trying to align IF coils, with no scope and little experience means you are either really brave... or really crazy!" "Well, I'm certainly not brave!" ![]() Realistically there's no point in trying to get perfect alignment. After all, there's nothing for the tuner to receive anymore, apart from whatever an RF modulator feeds it. |
| Audiokarma |
Oh. Goody. The tuning slug in L201 is disintegrating just like the one in L304.
That would explain the distorted audio, and the wavy lines in the picture from audio crosstalk. So yay... Happy Easter... I don't know where RCA got these tuning slugs, but these were definitely a bad batch, and probably why the CTC 120 is known for IF and audio problems. |
Easter resurrection!
It's an Easter resurrection!
Here it is, Easter Sunday 2025, and I have a resurrection of my own to celebrate! After replacing slugs in L304, and L201, I was able to get the I.F working *Good enough!* Is it perfect? No. I don't have a scope. I don't have test equipment. What I do have is perseverance. I think the replacement slugs were not meant for this TV as I had to adjust basically every coil in the IF and audio sections. A LOT of trial and error! This took me hours to get the picture you see in the video! But it locks solid. The audio crosstalk is basically gone. It's not perfectly aligned, but it's way, way better than when I found it! And I have further evidence that this set is not a high hour set, despite the worn buttons. The Screen control on the back of the CRT had plenty of room left on it. I don't think it was ever touched. Screen controls at factory default, plenty of room left on the drive and bias controls... I think I have a pretty good CRT here. So... Now that I have this thing fixed, or at least as fixed as I'm going to make it... I am going to do what we used to do with console TV's back when i was a kid: It's going to go up against a wall, I'm going to put a towel over the top, and use it as a table to set stuff on. Occasionally I'll plug it in and turn it on to remind myself that yes, I diagnosed and fixed this damn thing, and documented that the tuning slugs in CTC 120's can crumble into dust. |
The colors look fantastic. |
Congratulations ! Looks very good. We sold a lot of those sets and many customers continued using them with converter boxes past the digital change over. Except for lightning, it was hard to kill them.
It's *okay*.
The picture has a lot of ringing in it, particularly visiblle when reading small text, and there is a buzz when the picture shows white lettering against a dark background. I don't know if it's worth me trying to fix, especially since I have an RCA Dimensia which has a way better tuner. |
| Audiokarma |
