Old 03-02-2022, 09:54 PM
Try swapping the two 6HZ6 demodulator tubes with each other, and the two 6GU7 tubes and see if the symptoms change. I'm not sure if the color goes off completely, or you're just losing red.
he is also losing sync and definition, which makes me kind of suspect a voltage chain problem.
