Perhaps if there is sufficient improvement with the DC coupling it may justify your pulling the chassis again? |
No need to be sorry, I laughed at myself when I did it.
Will be following your results closely. |
I may try this on my CTC5 specials. I've already adopted the CTC7 adjustible HV reg circuit.
I spent the last few days working on the CTC5. The CRT is the original 21AXP22A with a date code of 56-30 ( 30th week of 1956). The emission on the three guns is good but the red gunntakes about a minute longer than the blue-greento come up.
The change made to the video amplifier to improve black DC level maintenance appears worthwhile. I ended up removing the 4700 ohm load and the ceramic 0.01uF capacitors as they appeared to do nothing. I followed the RCA supplement procedure for greyscale. The CTC5 does not have The convenient setup switch. But the process from the manual works well. I will summarize it below. For the Super chassis (without background control). This assumes the recommended contrast control modification has been done. 1. Set the three screen controls fully counter clockwise and the green and blue background controls backed off about 30% from full clockwise. 2. Unplug the tuner IF connector to provide a no video raster. 3. Set the brightness control so the the red gun grid bias is -70v. 4. Advance first the red screen control until a red raster becomes just barely visable. 5. Advance the green and blue screen controls so that the raster is dark grey/ black. 6. Advance the brightness control until the raster is bright without blooming. The touch up the blue and green background controls until the raster is white. 7. Reduce the brightness to the point the raster is about to disappear and touch up the blue green screen controls only for dark grey/ black. 8. Advance the brightness and touch up the blue green screen controls for white. 9. Re insert the IF link connector and reduce the color control to check the black and white video. You may wish to lightly adjust the green blue background controls for white highlights. The deluxe chassis has a red background control. It's initial set up is as follows: 1. Set the brightness control to minimum. 2. Set the red background control for red gun grid bias of -90v. 3. Continue with the Super chassis instructions Step 1 above. After some effort, the CTC5 is looking pretty good. The HV is 21.5kV and holding steady. (I earlier inserted a solid state HV rectifier which suffers less voltage drop and eliminates the filament load on the high voltage transformer. Here are,a couple of snapshots tonight. Last edited by Penthode; 11-08-2020 at 09:52 PM. |
