Old 05-29-2018, 08:18 AM
From what I see the CRT is a little weak. Do this.
Run a few days.
After 30 mn turn color all the way down, brite &
pix about 2/3 CW.
Turn green down.
turn blue & red up til you get it as B&W as you can.
With a weak tube dont run the bright & pix too high, it
makes it look worse. Run with auto color off if it has a switch.
With regular use it should last quite a while. It will very slowly
get worse over time.
Old 05-29-2018, 09:42 AM
Originally Posted by mr_fixer View Post
You are correct sir! chassis B2510PN . upon seeing the set the picture looked dim but got brighter after letting it play for 30mins. I told them i couldn't buy it with a dim pic but they came down to $20 and i figured worse case i could strip out the boards if someone needed them for a good crt set. Upon getting it home i figured i'd play with it a bit to see how good i can make it look. the main problem is there is too much green. i found 3 pots colored R, B and G i can barely get the green low enough to make a white image. is this a symptom of a weak tube or is there a board problem, here are some pics of the tiny chassis "my how they changed in 10 years from the vertical CC2 chassis.
Early post war TVs have the charm from the front of a big cabinet with a commically small screen, while first gen single/dual board ( ie no chassis full of modules) solid state consoles have the charm from the back of a big CRT and cabinet dirven by a commically small chassis... you could rent out all that empty space.
