Old 10-06-2017, 03:21 PM
LADR's Avatar
LADR LADR is offline
Местное и дх радио
Originally Posted by DavGoodlin View Post
Does that have the octal "service" receptacle on the back. There was 4-5 pins you could check vitals from, AGC, B+, ground oscillator AFC and something else.
Yes it does. I just pulled the chassis today to check tubes and components. The brite and contrast controls are rusted shut so i got alot to do. Oh yeah, this set is completely dead.
Old 10-06-2017, 03:43 PM
Try some penetrating oil (like PB baster) on the shafts.
Old 10-07-2017, 05:22 AM
LADR's Avatar
Местное и дх радио
Do you think WD-40 will work?
Old 10-07-2017, 08:31 AM
Tom9589 Tom9589 is offline
You could try WD-40 first, but PB Blaster will be more effective. I personally like Kroil from Kano Laboratories out of TN. It's a very effective penetrant. Kroil doesn't smell as strongly as PB Blaster.
Old 10-07-2017, 10:23 AM
LADR's Avatar
Местное и дх радио
Ive spray the two controls with WD-40 and it worked perfectly, but this set still has no signs of life. On the tube chart it says there is a thin copper wire for the tube filaments and i tried looking for it and i cant find the wire, so im having a hard time finding were this wire connects.
Old 10-07-2017, 10:44 AM
If it has fusible link (thin wire used as a fuse) it should be at the point where the fil windings of the power trans connects to a terminal strip. Usually fusible link is covered by heat shrink tubing to prevent shorts. Make sure your power transformer is supplying heater voltage and that it is getting line voltage.
