Old 05-11-2016, 09:11 PM
XP can still be run safely, and I'd still be running it on some machines if one had not suffered hardware failure and I had not gotten a windows 7 install disk.
I would not run any personal info through a XP machine anymore (there are probably security holes even with antivirus), but I see no issue with making one a bench computer for schematics and web reading. Just because you can keep something running does not necessarily make it the best option for important uses.
XP was great for years but it is becoming a dinosaur. Personally I prefer 7 and 10 on any machine that can support them.
Old 05-12-2016, 01:32 AM
Originally Posted by Captainclock View Post
You do realize that Microsoft no longer supports Windows XP right? If I were you I would upgrade to at least Windows 7, because otherwise your Windows XP computer is going to wind up being toast because of hackers or malware because XP isn't getting any new updates or patches anymore which means that your computer is completely vulnerable to malware or hacker attacks.
hehehehe. If I had a dime for every person who told me to get off XP because it's EOL'd and therefore insecure I would be on an i7 rig by now. Fearmongering.
XP or not, if you are stupid you are going to get hit anyways through shady downloads, freeloading ad malware or the good old suspicious emails with "funny_cat_picture.jpg.exe". Knocking on wood, I have not had a malware issue in years. I don't even run antivirus. I don't need it. Like seriously. The first step to not having system integrity problems is being vigilant.
Also, while regular XP home/pro/tablet/MCE was EOL'd in 2014 Micrisoft neglected to mention that XP Embedded (which is literally XP Pro) will continue to be updated until 2019, so a registry tweak means I'm still getting updates.
Old 05-12-2016, 07:37 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Only problem I have running older versions of Firefox and Win 7, once in a while I run into a web site that's all scrambled or won't work right. Then I get out IE 11. I don't like the unintuitive way IE works though so I always use Firefox with those very few exceptions.
Anyone know what's going on with this? For example, Home Depot's web site.
Old 05-12-2016, 10:05 AM
Ayep!
http://www.zdnet.com/article/registr...or-windows-xp/
I assumed it was common knowledge.....
All my XP machines are admittedly dual-boot Linux/XP machines, so in 2019, it'll be a worry.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 05-12-2016, 10:21 AM
A few tips: Save your self money on repairs by doing it yourself where possible. I use a boot software called clonezilla to copy my OS hard drives. If one of my OS drives gets corrupted, breaks, wears out I can take the image copy I made and restore data to the drive or a new replacement drive (if the original died) and be back on my merry way within a couple hours....Faster still if I made a duplicate OS drive.
I did not know anything about using computers till mid way through highschool, and could not build/repair them (had no reason to learn) till mid-way through college. If you have a second rig you can search for information to facilitate repair on the bad one.
I blew hours trying to correct the problem, I was having. Too frustrating!
I couldn't access anything without dumping the entire system. I didn't want to lose all the information, I've acquired like all 23 Riders, plus indexes and other schematics from ETF, etc.
BTW, I did correct my problems with U-Tube, using hints from this thread.
Thanks All!
Old 05-12-2016, 11:53 AM
Thanks All!
Make a Ubuntu boot/install disk (or USB stick), boot the computer that has corrupted windows OS from the Ubuntu disk and choose to try Ubuntu, but NOT install it. Your computer will boot after a few minutes to a GUI linux based OS and you will be able to browse your hard drive (assuming the windows boot/OS portion is all that was harmed, which is usually the case) and copy files you need to back up to an external memory device. I've saved my own bacon that way a few times (especially on my school computer).
At MSOE ones' computer is ESSENTIAL, and the IT department usually just says 'screw you' and wipes all your data and the OS and starts fresh when ones' computer won't boot...So as a student you either put up with that destruction of your hard work or lean how to fix it (and try to prevent it happening again) better than IT does...Necessity is the mother of invention and NOT redoing hours of work was good motivation to get my creative juices going.
I can even tell you how to potentially get back 'permanently' deleted files. (the longer they've been gone the lower the success rate)
Old 05-12-2016, 12:37 PM
lnx64's Avatar
lnx64 lnx64 is offline
Everything is vulnerable. As long as you take the right care, there's hardly a concern in my opinion. I haven't even had a single virus or malware in my entire life, and I don't even use scanners. I tried installing a scanner, just to find nothing.
Old 05-12-2016, 01:48 PM
I didn't want to lose all the information, I've acquired like all 23 Riders, plus indexes and other schematics from ETF, etc. :
If all this stuff is important to you then there's no reason at all to entrust it only to your hard drive, regardless of viruses or malware the drive itself can and will fail at some point.
For less than $15 you can get a 64Gb USB flash drive which is large enough to hold all your documents, pictures and videos.
I keep multiple copies of the important stuff in different locations for safety.
Old 05-12-2016, 09:51 PM
Banned
Originally Posted by WISCOJIM View Post
"completely vulnerable"?
I run several XP machines, as do may people here. I'm not so much worried about MS not having more updates, as my anti-virus and other malware software keep me pretty well protected.
Well I'm sorry to hear that because your computers are completely useless right now because since Microsoft doesn't support Windows XP or Vista anymore you're pretty much out of luck if anything happens to your computers if a virus or malware or even a hacker or cracker gets into your computer and completely destroys your computer or corrupts the files on there because of vulnerabilities in the system that aren't being fixed anymore. Don't say I didn't warn you. Also last I checked there aren't any current Anti-virus, and anti-malware programs that are being written or supported for Windows XP so I would like to know what kind of "anti-virus" or "Anti-Malware" software you're using on your Windows XP computers to make them "invulnerable", I mean considering that even Google Chrome and Firefox doesn't even support Windows XP anymore and Windows doesn't even support Internet Explorer anymore because they stopped producing Internet Explorer all together 2 years ago. So tell me again how your computers are "invulnerable" to attacks? They aren't and you're only fooling yourself if you think your computers are protected against hackers, crackers, malkware and viruses just because you're using programs that are probably no longer even supported by their vendors. The only real way your Windows XP computers would be truly invulnerable was if you didn't use them with the internet, but seeing as you've already admitted that you use a Windows XP Computer to access this forum then clearly your NOT invulnerable.
Old 05-12-2016, 10:06 PM
Ed in Tx's Avatar
.. you're only fooling yourself if you think your computers are protected against hackers, crackers, malkware and viruses just because you're using programs that are probably no longer even supported by their vendors...
That's a good one!
You're only fooling yourself if you think running the latest and most up-to-date OS and programs keep you from getting invaded.
Old 05-13-2016, 07:35 AM
lnx64's Avatar
Lol it's not completely useless if his computer still turns on and he can do something with it. Just because Microsoft doesn't support it, doesn't mean it isn't still able to execute programs, and do things.
Quit being one of "those".
Old 05-13-2016, 12:46 PM
OvenMaster's Avatar
DTV blows
The latest version of Firefox (46 as of this writing) is supported by XP SP2.
https://www.mozilla.org/en-US/firefo...-requirements/
AVG antivirus still works with XP
http://www.avg.com/us-en/buy-antivirus
Avast antivirus still works with XP
https://www.avast.com/faq.php?article=AVKB44#idt_100
A computer isn't obsolete until or unless it no longer does what you want it to do.
I learned long ago that as far as software goes, "new" does not always mean "better".
Tom
Old 05-14-2016, 09:43 AM
Kevin Kuehn's Avatar
Workin' Late Again
I don't think hackers wast too much time going after obsolete operating systems.
Old 05-14-2016, 11:00 AM
Ed in Tx's Avatar
The Comodo free antivirus I rum is still good on Vista, XP etc.
Supported OS: XP 32bit, Vista/Win7/Win8/Win8.1/Win10 32 bit & 64 bit / 152 MB RAM / 400 MB space
Only once have I been invaded, and that was a few years ago and I was keeping everything up to date. Had recently upgraded from XP SP2 to SP3. AVG failed to protect. AVG online tech support left me with a HDD that wouldn't boot. It would before they got directly involved. Finally I got my Acronis backup to work and restored everything like it never happened, onto a new HDD.
Backup backup backup!
