Old 06-19-2016, 01:51 PM
Look in Sams & see if it shows resistors & or caps
mounted inside the yoke. Compare values.
Also someone here has the factory manual, check
that too.
Keep in mind a slightly weak damper, output or osc
tube can do this & not show BAD on a checker.
Old 06-19-2016, 06:10 PM
heats00 heats00 is offline
Well, all that for naught...just looked at the old yoke again, and it is the 95-1768.
Zeno, I do have the factory service manual, it is what contains the conflicting data.
