Old 08-15-2015, 11:11 AM
In order to produce multiple bars, it'd hafta run at some multiple of the line frequency. Seems like that would require an active device of some kind. Tunnel diode maybe?
Perhaps a neon bulb???
This is a fun puzzle!
Old 08-15-2015, 01:46 PM
Originally Posted by Tom Albrecht View Post
How does it manage to sync anything with the sweep?
If the TV is tuned to a station, the vertical would be synced to 59.94Hz vertical sweep. A 60Hz waveform injected into the CRT would slowly crawl up the screen, slow enough so you could adjust the vert height and linearity.
