Amazingly, only one small chip in the front which I was able to glue back in place
![]() I found a copy of Sams 1394-1 that looks awfully close to mine and used it to order up some new electroytics. http://home.comcast.net/~jlrmsousa/p...14_1171d24.pdf Here's a video of me checking out the set and powering it up: https://youtu.be/-dRL0ar3F0g |
In your video you asked where the rectifiers were. One of them is directly under R401, it's a small green blob with a gray line on one end.
I think they were rated at 600v and 1a, they always got replaced with 1N4007 out of warranty. This may help someone else...since your's must be OK. rrrhre2s |
| Audiokarma |
I seem to recall that story being told by someone in my younger years. I'll check Popular Science and my Electronic Servicing and PF Reporter stash too. Cheers,
Brian USN RET 22YRS (Avionics/Cal) CET-Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
Any news with this set?
Bob,
I have a very water-soaked Porta-color I got for working on a set for another VK member. I think its the same set as yours but the label is faded It seems like it takes a hard fail like a fuse for these NOT to work. I dont remember any porta-color that couldn't easily be repaired in the 80s. Quote:
![]() I recall doing the install drill every spring for the older customers; furring strip on window sill, side curtain screws, bug strips and finally rope caulk all around.
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 07-22-2015 at 01:13 PM. |
fraid not. I've ordered up new caps. but have to finished up a few others projects before I can get to it.
The main thing, I found with Porta-Cools was the blower motors went bad after several years of use. I've seen them with the J.C. Penney name on them as well.
| Audiokarma |
