Old 03-10-2014, 12:36 PM
Originally Posted by egrand View Post
I'm pretty sure I read somewhere that Motorola made some later 23EGP22's themselves after the bad experience with NVC, and that they were much more reliable.
NVC did go bankrupt and out of business in I think 1969. I believe the 23EG was the only color tube they made. Supposedly their B&W's were still ok, but by the late 60's most OEM's had gone overseas for B&W and nobody wanted them to make color ones.
NVC made a 23V type CRT in the later 60's. I scrapped a Late 60's Magnavox color set, that was fire damaged and only two years old. The CRT, tested perfect and was NVC sourced. I installed it in an Admiral set.
When Motorola started selling 23V sets, they were buying CRT's from Admiral and Westinghouse. They were using them in the lower-end models. The higher-end models, with the Drexel cabinets, usually used Sylvania CRT's.
Old 03-10-2014, 05:15 PM
Originally Posted by mcmlxv View Post
Can anyone shed some light on post-EGP23 tubes used by Motorola? I was just reviewing a set of original Motorola paperwork from a set purchased May 9th, 1970. The chassis is R23TS-921-D04, and the model number is CU876ES. I found something interesting: on the factory schematic, the CRTs listed are 23FVP4 and 23DYP4.
It appears Motorola was no longer installing the 23EGP22 at this late date of tube TV production. Maybe Motorola ditched the 23EGP with the introduction of the TS915 series chassis in '67.
Any thoughts?
The set you have is a monochrome(black and white) set. The sets we are discussing are color.
CRTs that end in 'P22' are color, ones that end in 'P4' are monochrome. Monochrome rectangular tubes were first produced decades before color rectangular CRTs.
Old 03-10-2014, 05:17 PM
Mal Fuller Mal Fuller is offline
When the 23EGP22 entered production, Corning Glass, then the US source for CRT envelopes, did not yet offer a rectangular color envelope. National Video engineers built the 23EGP22 using what had been intended to be a black and white envelope.
The 2EGP22 offers strong proof of this fact in that its 2nd anode connector is at the side of the funnel, while the later rectangular color tubes have the 2nd anode connector at the top center of the CRT envelope's funnel.
Old 03-10-2014, 06:42 PM
mcmlxv's Avatar
mcmlxv mcmlxv is offline
Got it. Should have been more careful reading that schematic. I don't own the set, it was included in some bagged factory literature that I found together with a owner's manual for a 60s Motorola color set.
So that begs the question, when did 23EGP22 installation cease in Motorola's tube sets?
Thanks everyone!
We think it's a better way to build television.
Old 03-10-2014, 07:52 PM
The two tubes you list are B & W.
julian
Old 03-10-2014, 07:56 PM
Thanks everyone!
I would say, the 1967 model year. The other firms that used them, seemed to cease using them, at around the same time.
Old 03-11-2014, 07:19 AM
I got a question about that tube....
As a kid I picked up an Olympic set with that tube in it, I fixed it and used it in the patio for a few years, It had a weak tube, but watchable..... The tv was I believe a '66, '67, But the tube may date it differently.... Was this 23EGP22 sold to other tv companies like Olympic ? I know Olympic was most likely not a major brand at the time, and the chassis itself may bave been supplied by RCA for them to sell.... So also if RCA did not sell tv's with the 23EGP22, did they build a chassis for others to spec, which may have included designing for the use of this tube...? Or was the Olympic I had actually made by Motorola because it had the 23EGP22....? Do you guys know if this tube made the rounds to other tv brands besides Motorola, and Olympic.... Thanks.. Does anyone know if that tube responded to rejuvination attempts....?
Old 03-11-2014, 08:50 AM
holmesuser01's Avatar
I think Dad bought a 1968 Motorola 23" set. We liked it because it had a color indicator light above the tuner that came on when a color show was playing... Never mind the big giant 23" screen just to the left of this light...
Within a year, the CRT went bad. Motorola replaced it. Within about 7 months, the second tube failed. Again, Motorola replaced it. After about a year, the third tube failed. By then, Sylvania had a replacement available (and it cost more) so Dad went for it. Motorola refused to warranty replace the 3rd tube with a Sylvania, so dad paid for it, and informed the Motorola dealer that they had seen the last of his business.
We even got a big letter from Motorola Corporate over this, too, offering a big discount on one of the new Quasar sets with the works in a drawer.
The 4th tube survived. We kept the TV until 1975, when we got a 25" Magnavox with their first solid state chassis. It had it's own issues... a small arc that burned the PC board, but it ran flawlessly until 1981, when it got hit by lightning. We gave the Motorola to my grandparents, and it ran for years for them.
We had zero issues in all that time with the Motorola chassis.
I've seen only a couple of Motorola 23" sets in the past 40 years or so with a good Motorola branded CRT in them.
Bruce
Old 03-11-2014, 09:32 AM
According to the Sams field service guide, it shows the several firms used the 23EG. The sets that I have experience with using them was Muntz, Emerson, Westinghouse, Admiral and Packard-Bell.
It seems that everyone used them but, Sylvania, RCA and Zenith.
Old 03-11-2014, 09:59 AM
ok, Thank you ! !
Old 03-11-2014, 12:08 PM
marty59's Avatar
marty59 marty59 is offline
I had done a conversion job on a Magnavox using a Motorola kit.
And I do seem to recall rebuilders staying away from them too.
Old 03-11-2014, 01:17 PM
I still have to convert a Motorola 23EG set to 23v type CRT. I bought a Motorola conversion kit on the E-place. Problem was, it was missing some of the parts I needed. I did come with the instructions and the paper mask template needed to alter the front bezel for the larger tube.
Old 03-12-2014, 10:40 PM
If memory serves, I've seen a GE schematic with a 23EGP22. You can often tell sets that use this tube as it has a more rectangular shape than the 23v.
Old 03-13-2014, 12:29 PM
DavGoodlin's Avatar
Motorola Minion
Yes, that would be the CB23 chassis (also CB21 and CB25 versions) , before the KC of 1967.
-Dave G
