Old 09-17-2013, 08:12 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
I remember my Dad had one of those from the 300 Ohm twin-lead to the back of the TV. Idea was to easily disconnect it in a lightning storm or when moving the TV out to clean behind it. Got rid of all that in the late '60s when we put up a Winegard "Super Colortron" antenna with the new-fangled 75 Ohm coax.
Old 09-17-2013, 10:29 AM
kx250rider's Avatar
REAL TVs have TUBES!
Radio Shack had a package of those in various colors, but last time I saw them, must have been 1979-ish. I'm sure they show up on eBay now & then. All TV repair shops had them for the bench antenna connections.
Charles
Old 09-17-2013, 02:22 PM
DavGoodlin's Avatar
Motorola Minion
Originally Posted by N2IXK View Post
Were these connectors ever that common?
The whole reason for them was to be able to quickly connect/disconnect the antenna wire. Not something that the average set owner did often enough to care about.
The only place I ever saw them used was on repair shop service benches, or on the output of portable test gear like bar/dot generators. Once the 75 ohm era came along, we used the push-on type F connectors for the same reason, but they were a lot less durable...
Mostly they were found in homes of folks who disconnected the antenna wire during a thunderstorm.
Thanks for the photo Marty, you got all the colors too!
-Dave G
Old 09-21-2013, 09:06 PM
BigDavesTV's Avatar
BigDavesTV
These clips are great! I still have 3 of them, I bought them in the mid-seventies, new, and I use all 3! Makes switching the 75 / 300 ohm adapter to set's VHF Input so easy, also FM Tuner Ant. inputs as I switch to different sets.
