Your scope is pretty old, and non standard by many modern scopes. But it looks like you could still use it for learning about tv and radio. The most important thing I remember about old, and new scopes is before you do anything with an old radio or tv, is to be sure both your scope and test item both are using the same ground. Put a volt meter between the scope ground and whatever you are planning on looking at, or working on. If 0v you should be safe to hoop it up,(ground to ground) just be careful if you unplug anything, remember ac plug polarity, on many sets one side is ground, and if not polarized, and you unplug, and then plug it in again, you may get a spark show.
Your scope lets you choose "sweep circuit osc." from the horoz. on the left. That will set your horiz scan rate. And there are sync select knobs too. Use int. sync. You have a signal source there called the radio frequency osc. You can take the output of the RFO and put it into the vertical and keep all gain and output settings at min. slowly increase till you see something. Then play with the sync. to get the picture to lock. You have a neato free-bee learning thing there. I'm pretty sure the one thing you will not be able to see on that scope is a signal with a DC offset. To learn more about how a scope works ask the great wizard of oz... He knows everything (google) "how do I use an oscilloscope" and other words to that effect. On that one, you can begin just using clip leads to and from the various things on the scope itself. And besides if you get a more modern scope and overload it or connect something the wrong way, you'll be then needing to replace transistors or other stuff inside. That old 505 will be very forgiving, and a great scope to learn on. Once you learn a little about it, start poking around inside a transistor radio, plenty of good stuff to see there. And that scope is fully an X-Y mode scope, just put both vert. and horiz. inputs at the top left and right to ext. and then attach something to those inputs and you have X-Y display. (Again be careful with the grounds!) Some of those things might even have a Z cutoff. I have one like that made by one of Tektronix's little brothers.
Yes you can call me "Squirrel boy" Last edited by Username1; 05-11-2013 at 04:26 PM. |
https://www.sparkfun.com/products/9306 I tried it before I recapped the scope, but it was a disjointed image. Haven't tried it since, as I was under the assumption that it wouldn't work. On the PCB, there's an X, a Y, and a ground. Do I ground it to the scope, and if so, where?
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
It will never work to your satisfaction. You need, I think, a direct coupled input circuit, which the Hickok does not have. So every time the time changes the display will bounce and move to a different spot. I am not familiar with that clock but it may have a digital output, which makes further demands on the 'scope.
You may remember that I said your scope most likely will not be able to show a wave form with a DC offset applied to it. Your clock most likely relies on a dc offset to put that picture on the scope. Because you can not get a display with dc offset, the clock may move around the screen. In a way, you are seeing what some people here complain about when a tv does not have a dc restoration circuit for picture tube bias.......
The ground form the clock can go to any ground post you see on the front of the scope. Your X and Y go to the vert, and Horiz. input at top right and left on the scope. Most likely not the direct input since its a 15v and 30v input, your clock is most likely less, so use one of the other low voltage scales and that includes access to the amplitude adjustments on the scope, its in the instructions. And also when the sync is set to ext. you have access to a Z axis blanking of the crt, that is pretty special for stuff like turning the scope into a clock because you can blank the retrace lines..... Read that instruction book a few times.... Your clock also has info on using the z axis its in the faq's Now if the cycle time of the clock is fast enough, and it sounds like it is.... then the 505 will not be such a factor in not supporting dc offset because the clock cycles the screen so fast.... Since you already have it you gotta try it. You can look into lowering the baud rate if you need to for the slower scope you have....
Yes you can call me "Squirrel boy" Last edited by Username1; 05-16-2013 at 01:55 PM. |
| Audiokarma |
does it have a lotta lights that flash...?
Now you need a few metal boxes wit stuff that turns by itself, like lost in space alien matter generator machines, and a bigger box what has those spark things that climb 2 metal rods like in the Frankenstein movies...... And a fog machine. Then yer set!
Yes you can call me "Squirrel boy" |
The only thing creepier looking than old TV test equipment to the casual glance would be vintage medical equipment, when you think about it
I agree old medical equipment is very creepy. Old electronics however has that Sci-Fi mystery look to it. I for example love my old Hickock Oscilloscope, I think its got somewhere between 20 and 500 tubes tons of knobs, a sweep delay that is very much looking like a combination lock dial, a big RED pilot light, metal toggle power switch next to the pilot light, and a 8" fan and air filter in the back. And oh-yah 2 handles on top and weighs about 100 lbs. And has a IIHS 5 star crash test rating from the institute of electron tube safety for all the tubes inside.
