Old 11-30-2012, 03:17 PM
Kevin Kuehn's Avatar
Workin' Late Again
Originally Posted by IsthmusTV View Post
But the range of adjustment was relatively small. I don't think that it would be enough to fill out the width in your case.
I agree about the adjustment being minimal. I think I'd first take a look at the horizontal drive signal or horizontal output.
Old 11-30-2012, 04:02 PM
I experimented with a width sleeve when restoring my Capehart-Farnsworth 661-P. This article includes some explanatory paragraphs from an old TV service book:
http://www.antiqueradio.org/Capehart...Television.htm
The book says the ground connection is to prevent arcing from the sleeve to yoke windings.
In my casual experiments, pushing the sleeve in and out had quite an effect (granted, this was on a TV designed to use a width control, not a sleeve).
I don't see a sleeve in Bob's photo, only a ring. Is the sleeve pushed all the way into the yoke so that it's not visible?
Phil's Old Radios
Old 11-30-2012, 04:18 PM
Originally Posted by Phil Nelson View Post
... I don't see a sleeve in Bob's photo, only a ring. Is the sleeve pushed all the way into the yoke so that it's not visible? ...
Bingo I need to take the set apart again and dig it out
Old 11-30-2012, 05:59 PM
I found it
That's better Thanks for the quick help guys
Old 11-30-2012, 06:35 PM
It's hard to understand how a thin piece of non ferrous metal can affect the magnetic field enough to cause that much of a problem.
Old 11-30-2012, 06:56 PM
Workin' Late Again
Yeah, that was pretty dramatic. That really shows how big of a problem a single turn short in the yoke would be. The service book Phil referenced said they came up with that idea in the late 50's, however my Setchell Carlson 25 chassis had a width sleeve as early as 1951. I wonder if Bart came up with that idea before its time.
Old 11-30-2012, 08:26 PM
I was quite surprised it had that much of an effect too. The height also increased about 20% with the sleeve slide back into it's original position.
Old 11-30-2012, 09:24 PM
When I experimented with a (copper) sleeve, it was able to block the sweep completely.
Old 11-30-2012, 10:00 PM
That reminds me of this neat YouTube video showing how a rare earth magnet reacts with different metals. http://www.youtube.com/watch?v=VEIYXomRdLY
Old 11-30-2012, 11:13 PM
Workin' Late Again
Great video.
Old 12-01-2012, 10:20 AM
Does anyone know where I can get twist tab panel mount pots like this ? AES only has 250K and 500K, but I need 25K and 750K.
http://www.tubesandmore.com/products/R-V500K-N2
I would try soldering a control nut on the original pot mounting plate.
Then you can thread on the replacement pot. I've done it before.
Get out the old 200 watt American Beauty.
Old 12-14-2012, 02:07 PM
Why did you need to solder it to the plate ? I can just tighten it down with a wrench. The issue I have is that the pot shafts can only stick up about 3/8 of an inch from the mounting plate.
My AES pots arrived today. They're nearly identical to the originals except the shaft is too long.
A Dremel tool and cutoff wheel took care of that.
Much better
Old 12-14-2012, 07:05 PM
Much better
My reasoning was to solder the nut to the bottom of the original twist mounting plate. That was the intent, if the treaded bushing would protrude too far, so the shaft wouldn't be long enough to retain the knob.
Did you use the original carbon element from the old controls?
Old 12-14-2012, 09:36 PM
Got it. Thanks for the great tip
The original carbon was trashed so I had to go with new controls.
Old 12-15-2012, 09:40 AM
According to the former post, you said that AES didn't have the proper values. That's why I was inquiring about the pots.
