Old 11-13-2012, 04:15 PM
DavGoodlin's Avatar
Motorola Minion
I think 1958 may have been the first year with a 318 cubic inch V8. I had a radio from one when I was 11. It was a Motorola with a bright white slide rule dial and a square profile from the side. It worked great on my HO model train transformer since the radio's vibrator supply filtered the DC.
Old 11-13-2012, 07:01 PM
This article shows the 318 as being available in 1957... My brother and my Father-in-law both owned 57 Belvedere 2 door hardtops and I am *fairly* certain that they both had 318s.
http://www.allpar.com/history/chrysler-years/1957.html
Some lovely "Finned Mopars" shown in the article.
Old 11-13-2012, 07:56 PM
If the Mopars of that era were "Willowy", the T-Birds & Lincolns were NOT. They were almost laughably OVERBUILT... The '58 Lincoln was pushing 5300lbs, Ford has to make a GINORMOUS 430 CID engine to be able to make the beast able to get out of its own way..The '58 Lincoln had the LARGEST unibody construction ever attempted to that point..I think only the Mercedes 600 series from 1963-81 ever exceeded them in size..
Old 11-13-2012, 08:12 PM
ggregg's Avatar
ggregg ggregg is offline
Gotta remember though, the first 318's were a different block than the one most of us are used to. The wide block 318 was used until about 1964 I believe. I'm not positive but I think it's the same block as the 361. I'm pretty sure you could only get a 318, in 1957, in a Fury which at the time was the TOL two door hardtop only, like Lee has. But back in those days, you could probably order whatever you wanted.
AFAIK the unibody came out in 1960. Torsion bars in 1957. Kool Kar.
Old 11-13-2012, 09:39 PM
According to Allpar, there are two 318's.
The early ones were the "A" block. The newer ones were "LA" block, which meant "light weight A". LA engines were introduced in 1964 as the 273.
A while later they were bored and stroked to 318 Cu. That engine also became the 360 and the V-6 and the V10.
Old 11-13-2012, 09:43 PM
My Mom's 65 Belvedere had that wide 318, the one with the bolts through the valve cover, primitive looking beast compared to the modern small block version.
I always heard them called the Canadian 318 but I don't know if that's true.
Old 11-13-2012, 09:44 PM
The 58's were already hybrids.
The last year for OEM Motorola radios with vibrator P.S. was 1956.
Old 11-14-2012, 08:56 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
That is an awesome car.
Please, please don't make a Christine Clone out of it! it's been done to death.
Member M3-SRT8 aka Lee has one of these I believe.
Generally, I'm a purist when it comes to cars. Not this time
The tentative plan here is to stay with the Savoy trim, but do the red and white paint scheme. Depends how the car looks, though, once I get it here.
I want not only a fantastic looking car, but something that's very roadable....which means that the front drum brakes are going to be replaced with a bolt-on disc conversion, and I'd like to yank the original engine and replace it with a somewhat more modern Mopar V8 with dual exhaust. The motor in this car is literally half apart anyway, so doing it that way will save me both time and money. If the car has vacuum wipers, they're history, and no bias ply tires this time .
Resurrecting the Buick has taught me a LOT about how to build a car to be a daily driver, or since I live in Buffalo, a summer daily driver. I'm not going to do anything stupid to the car, but some things are going to need updating.
I saw the picture of Lee's car, and two things are apparent. First, that he's a purist, and to be commended for that. I'm also betting that his car didn't start out a rebirth as bad as mine is, or if it did, he's got deeper pockets than I do . Either way, if it's the car I think it is, it's as perfect as I've ever seen....
Old 11-14-2012, 03:09 PM
magnasonic66's Avatar
magnasonic66 magnasonic66 is offline
I saw a black 1961 Impala 4 door flattop sedan today, that looked spectacular, except for those ungainly gigantic custom wheels and skinny tires. Leave those off of nice cars, put them on something newer and more common please.
Old 11-14-2012, 04:07 PM
Dude111 Dude111 is offline
Analogue is Awesome
Good for you buddy,i reckon you will fix her up nicely
Old 11-15-2012, 12:06 AM
marty59's Avatar
marty59 marty59 is offline
Does unibody imply "no frame" or something simpler like "major passenger compartment panels are all welded together"?
These pictures of a 58 restoration show a frame:
http://rob58fury.tripod.com/progress.htm
I stand corrected, I should know as much as I'm a Mopar Guy for the most part. But all old cars are cool!
When I was (way) younger we had a '61 Fury with a 4BBL Polysphere 318 and that thing would run! When the 318 became the LA smallblock, it became pretty much a Mom an Pop utility engine with only a 2BBL until the later M-Body Copcars were available with 4BBL's.
Old 11-15-2012, 11:57 AM
DavGoodlin's Avatar
Motorola Minion
The 318 LA engine is a favorite powerplant of the demolition derby champs upstate. Just about all of the Newports and other boats entered had their 383/400/440 B engines swapped with a 318 because it can run longer than the others without coolant. They duct-tape hell out of the u-joints, a Mopar weak point.
Old 11-15-2012, 12:38 PM
I remember reading somewhere that Imperials of the 1957-66 era, ESPECIALLY the 1964-66 editions, were almost UNBEATABLE in demo derbies..They'd pack the fenders w/concrete, & use 'em as battering rams...
Old 11-15-2012, 01:59 PM
Make you shudder to think about using those classics for a Demo Derby today but they were just old cars then.
My Parents had an Auto Salvage yard in the 70's, a lot of now classic cars went through there, some were bought and saved by collectors, others were stripped and crushed!
I remember being upset when they donated a 51 Pontiac Station wagon with a Flathead straight 8 for the Demo Derby, it was running of course.
Then there was the pristine 58 Chevy Wagon that had to be crushed intact because it was a Police Impound with no papers (mostly intact anyway, I hear a few parts got away)
Old 11-15-2012, 04:28 PM
The 1964-66 Imps were designed by Elwood Engel, who had also been instrumenta lin designing the 1961 Lincolns...THAT'S the reason the Imperials kinda looked like the Lincolns...When I bought my 1st "Suicide Door" Lincoln in Dec. '82, it was a Chevy/GM dealership where the old guy who owned it had a fondness for Mopars...There was a Airflow Chrysler that wasn't TOO bad, a Superbird, a '65 Imperial, another couple of Mopars that I can't recall now,& the Lincoln...The Imperial got a pretty good lookin' at by me, but in the end I went w/the Connie-Gotta LOVE them suicide Doors, y'know...That,& I think he wanted $2500 for the Imp- The Connie was $1K. The old Airflow, he only wanted $5K for, & it was in running condition...Don't remember what he wanted for the Superbird, but it was likely WAY beyong my meagre budget.
