Old 04-24-2012, 12:05 PM
kx250rider's Avatar
REAL TVs have TUBES!
Originally Posted by Sandy G View Post
I had a 25XBR-EXCELLENT picture, crummy outrigger speakers, but it started "Goin' South" around 1990-91-The screen would go almost totally DARK, except for some red-it was like the blue & green just died, & the red almost so. Then it would light back up, as nothin' had happened. I bought it offa some catalog place, it was too big to try to lug to some Sony dealer & have to argue w/them, since I didn't BUY it from 'em... The speaks-they would quit working for no apparent reason, you'd jiggle the wires, spit on 'em & plug 'em back in & they'd "Gee & Haw" OK again for awhile.
Classic problems with these, but easy fixes... Bad solder connections on the delay line, and on the CRT socket board were the usual causes of the video dropping out, and seeing only chroma (no luminance). The audio output pack (STK-xxx), would go bad with internal bad connections.
Old 04-24-2012, 01:35 PM
Wished I'd known THAT Back Then... This was Sony's Flagship TV then, looks like they'd been a LITTLE more careful in the construction/QC of the damthing...IIRC, this Bad Boi was $1500 or so then-a LOT of Munny for an effin' TV-Even the TOTL Sony at the time....
Old 04-24-2012, 03:04 PM
The XBR I had back in 1990 (kv27xbr10) Started blacking out every now and then after about two years of use. Smacking it on the side would fix it for a while but of course the ultimate fix was to take it apart and resolder it.
I was not happy about having to take apart what was a very expensive almost new set, however it continued to work for 15 years or so until it got replaced by a HD set.
It was still working when I gave it away a few years ago, the CRT was getting a bit soft but it still looked good if you kept the brightness reasonable.
