Old 12-07-2011, 02:39 AM
Originally Posted by leadlike View Post
I've come across similarly-constructed radios, and even an electric piano made in Japan during this period. It seems those cabinets are all very much hand assembled. I typically find quite a bit of writing in them, indicating cabinet measurements, I guess. Build quality is always very crude, like this one.
Like your tv, a lot of the stuff I find seems kind of one off, at least on English language web pages, I don't find much info. It may be possible stuff like this was purchased by a serviceman stationed in Japan and brought home.
Thanks for the info.
Originally Posted by Sandy G View Post
Well, WHATEVER it is, & HOWEVER OLD it is, I still like it...GREAT Score !
I found this label on the picture tube. It's a Hitachi 210CB4 I think from the 10th month of 1962. The rest of the inside make me think early 60s too.
Originally Posted by ctc17 View Post
Change all those green caps!!!
I assume that means they have a high failure rate ?
If it was purchased in Japan rather then made there to sell here it would have Japanese control lables.
True unless it was marketed to American servicemen.
Originally Posted by radiotvnut View Post
Nice set! Probably not many of those left.
Thanks. I bet not. No useful info in the Internet so far except what I get here
I pulled the chassis tonight and here's what I found.
Very clean inside. All but a couple tubes are Hitachi branded including the CRT.
Judging by the tubes #s, it's a series filament set. Perhaps the power transformer is just for B+ ?
12G-B3 and 12R-K19 HOT and damper tube. I'm not at all familiar with this Japanese numbering system.
Picture tube tests like new
Old 12-07-2011, 09:09 AM
looks pretty much unmolested with all those paint drops. all those grey caps are prob bad, I had a kenwood receiver with them, EVERY one of them leaked badly, just like a wax paper cap. Super clean chassis, that's going to be a sweet setup when you get it done.
Old 12-07-2011, 11:04 AM
It looks like the transformer is an isolation transformer, as there is nothing isolated from the chassis. Notice it has a primary for 117 volts. Japan still uses 100 volts, both 50 & 60 hertz, so the set was intended for export. Those sweep tubes are replaceable by 12AF3 and 12BQ6.
Old 12-07-2011, 06:08 PM
maxhifi's Avatar
maxhifi maxhifi is offline
This is, perhaps, my favorite item i've seen on this site all year! Great find!
Old 12-07-2011, 06:16 PM
Seems like I've seen one or 2 of these things over the years on Fleapay...
Old 12-07-2011, 06:52 PM
Is the power transformer ok? That "smoky" pattern on the chassis near the upper corners looks like it could have gotten pretty warm.
Old 12-07-2011, 09:25 PM
Thanks for the tips. I see what you mean about the discoloration above the transformer. I haven't tested it yet, but for sure one resistor fried. Looks like it's in the vertical circuit.
Old 12-07-2011, 09:32 PM
ctc17 ctc17 is offline
Most of the Japan sets from that era used those green wax capacitors. I have never seen a good one. They get really leaky or short.
They grey ones are better, but I had a set where the boost filter got real leaky and overheated the flyback.
At a minimum I would change the green wax ones, the one that couples the signal to the horizontal output tube and the boost filter.
The Japanese electrolytics are awesome, no need to mess with those unless theres an issue.
Old 12-07-2011, 09:54 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
That is one neat little set ...I have some oddball Japanese TV schematics in a folder, might be able to match something up as its a TV/Radio combination. I've got Hitachi/Sony/National/Crown/Sharp/Mitsubishi/NEC and most are tube b/w schematics. Worth a shot?
Those green and grey oil filled caps...pull 'em out and toss 'em They'll all be leaky and more than likely be the cause of the burns up you can see... Sorry just read the comments above, so I won't repeat what others have said about them
Cheers
Glen
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
Old 12-08-2011, 12:54 AM
Cheers
Glen
Sure, if you wouldn't mind looking
I haven't pulled all the tubes yet and there's no tube chart, but here's what I found so far. I'll dig back into the set soon and get a complete list.
12G-B3
12R-K19
12BH7
6BE6
6AH6
Old 12-08-2011, 10:52 AM
I don't think there was that many of those to begin with. Too expensive for a novelty set. I like the way the power supply diodes were replaced. It looks an American hack technician repaired it.
Old 12-08-2011, 11:24 AM
TerrySmith's Avatar
TerrySmith TerrySmith is offline
Also looks like some butcherin' around the HOT socket, I would verify the parts values before powering up.
That is a very interesting set, can't wait to see the video and the finished product! I wonder why the chassis is designed with the tubes inboard?
Old 12-08-2011, 01:44 PM
Hemingray's Avatar
Hemingray Hemingray is offline
Vintage Geek
I also see a charred resistor in pic #2 on the far left.
Death: Man how old is this TV?, You probably get the DuMont network on this thing!
Old 12-08-2011, 01:54 PM
Good question. The only way to service the tubes is to pull the whole chassis out
Yes indeed - it's charred and I can't read the value
Old 12-08-2011, 03:50 PM
radiodayz's Avatar
radiodayz radiodayz is offline
radiodayz
Very cool! Yeah, that would have been my guess--closer to 1960 than 1970. Good luck with it.
I have one of those around here, somewhere
