You would certainly blow the traces off the bottom of the PCB, I've done it before. If it has a switching power supply, any number of things could be wrong. If it's linear, just keep disonnecting things in the circuit till it stops blowing fuses.
Evolution... |
I don't trust rednecks or their "engineering" (spent enough time around them to know better), though I have Mac Guivered/jury riged some stuff back to life. There comes a point when one has tried fuses so large that one may as well connect one prong of the plug to ground, the other to 20' of bare copper wire, tie a ball to the 20' of wire and throw the ball across the nearest high tension powerline to see what happens.
That Monty Python sketch was a classic.
Sony Trinitron Fan |
Benevolent Despot |
| Audiokarma |
