test point D on the set, its on a term strip, if you are lucky you will see a paper tag on it, or it may be stamped into the top of the chassis IIRC. its not a wire on the tuner, its after all the IF stages, then there is a diode (which could also cause the issue but I doubt it).
I assume not only are the tubes good in the tuner but they are lighting up and getting B+ as well? the cap will block any DC from the set, there should not be any, but it just in case you inadvertantly touch a B+ it will save your DVD. Aways a good idea to check the TP with a multimeter to check for DC before connecting anything up. opps hold up, wrong zenith, I will have to check to see if that D is still the right test point well not sure I did not have that schematic I have a 25NC38 and a 24MC32. You need to get a schematic for that, one of the video detector output test points will be indicated. that is the composite signal. done expect it to be a great pic, the PP is prob not going to be the same, but you will at least see something. the other way to check would be just to scope it if you have a scope. Last edited by DaveWM; 10-13-2011 at 02:13 PM. |
I finally got a chance to check over the set. What I hadn't noticed before is that the first 6EH7 tube in the IF wasn't lighting. I rechecked the tube and it tested ok. I straightened the pins on the tube so that it would fit the socket better, and it lit. Sound and picture are now back, even better now with the new tubes.
tube wigglling is always the FIRST thing to do on a very old tube set. Glad you got it going. some contact cleaner and a brass bristle brush on the tube pins is aways a good starting point on a restoration of an old tube TV set.
I have also restored old radios and TVs to operating condition by simply wiggling tubes in their sockets, cleaning said sockets with contact cleaner, and straightening pins. Sometimes the most obvious and simple things (such as your set's 6EH7 failing to light) can stop a TV right in its tracks. When I lived in a Cleveland suburb some years ago, I would pick up old radios and televisions on trash day; many of these sets had literally nothing wrong with them except one or more loose or dead tubes. I once had a Zenith table radio which I picked up at a thrift store; the set wouldn't work, but within five minutes I found out why. A fusible resistor under the chassis was open. I replaced it; the radio immediately began singing again.
Hold on to that Zenith 24NC31Z TV if you can, as they don't make them like that anymore. Those older Zenith color sets were built to last and to work well, which is more than I can say for a lot of the offshore flat-panel sets these days (although my Insignia 19" FP, bought new in August this year, has a better picture, IMHO, than either of my CRT sets, both 19" as well). When you bought a Zenith you could expect it to last 15-20 years easily; today's FPs (yes, even the ones with the Zenith lightning bolt on the display panel frame) are made, or so it seems, to last two years or until the end of the warranty period, whichever comes first. The original Zenith Radio Corporation's emphasis was on quality, not just in the television chassis itself but also the cabinetry -- those old sets had solid wood cabinets, although compared to other sets Zenith cabinets were rather plain-looking. The pictures on these older sets, however, were excellent by late-1960s NTSC standards; typical Zenith. Hook up an ATSC->NTSC converter box and an antenna to your set and get ready to enjoy TV as never before -- the converter box will allow you access to more channels (carried on subchannels of your area's network affiliates) and will even convert your set to remote control, except for power switching. The TV on-off button on a DTV converter box remote will not work if the television is not already set up for remote power switching, although all other basic functions offered by the box (volume +/-, channel +/-, mute, et al.) will work perfectly. I mentioned in another post to a different thread that the remote on-off switches on a very long cord can be used for TV power switching, although I don't think these switches are available anymore except, perhaps, in thrift stores or at flea markets. The trend these days is to wireless remote control, so your best bet is probably to find a wireless remote unit as used for lights. However, be sure the controller (the unit that plugs into the AC outlet and that your TV plugs into) can handle the power draw of your set. Many if not most of these wireless remote systems are intended for use with lights only; they cannot handle a 300-watt-plus load -- the relay in the controller will be damaged or destroyed instantly if it is used with an old TV, or anything for that matter, that draws more than 100 watts.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. |
Chris Quote from another forum: "(Antique TV collecting) always seemed to me to be a fringe hobby that only weirdos did." |
| Audiokarma |
After seeing one of those "Christmas" remotes at a friends house (he was using it to control a table lamp) I had to find one. Originally I wired it into a ceiling fixture which didn't have its wall switch in a very good location. That little remote is very handy. Wait 'til the end of the year, you can probably pick one up cheap. I wonder what other functions you could rig them up to do?
Bryan |
I just thought of a good use for one, if they can handle the power: Plug a power strip into it, and then plug all of your regular TV devices into it (TV, cable/satellite box, Blu-ray player, stereo system). Then, when those devices are not being used, you have a "hard" power switch to eliminate all of the standby power used by them. The same concept can be used for computer equipment (CPU, monitor, speakers, maybe printer except some printers use extra ink each time they are hard-powered on).
I think if you have several televisions plugged into a power strip and flip the switch, smoke and sparks will come out of that little switch. My guess is that they are good up to no more than 100 watts. A decent color set (vacuum tube type) will draw about 300-325 watts. Now have several on at the same time and stand back!
Some of the wired Power "remotes" can handle a TON of juice. I've had one set up to handle the front half of the masssive Christmas light display (I had to seperate it into halfs as the load was too much for the GFI outlet), and it could handle all the the current that the GFI could stand quite well.
I know first hand how much juice Color sets can draw....I have a wall of color sets (shown below) and between the four sets, my stereo, the lighting, and what ever was on in the other rooms on that line I was able to trip the breaker.
The roundie has the nicest picture. :p
Evolution... |
| Audiokarma |
The bottom or the top one?
The color bars on the bottom one look much better.
Evolution... |
Seriously?If you read my post you probably know why that sets "picture" looks different. I coulden't run them all at once (without going to the effort of stealing power from the air conditioner outlet) and the bottom one despite haveing what I think is the best grayscale among them has lousy colorimetry, and the color bars tend to bleed into eachothers edges, not to mention other small issues that I will someday take on. The upper roundy has(especially back when I took that picture) great colorimetry, but has some small issues that detract from that. I usually run the top two, and (when the rectangualr one is not having focus issues) watch that one for fine detail/ledigible text, and watch the roundy for that glorious lolipop color.
Would anyone have any spare control knobs ( the ones behind the flip down door under the CRT) for the set in the thread title? I'm missing ALL of them.
Thanks, Frank |
I have the control box complete with knobs for a Zenith roundy, but I don't know the model. It can be seen in the right midle of the photo. If the knobs look right to you let me know.
| Audiokarma |
