Old 07-02-2011, 06:39 PM
I have several CRT VGA monitors. I like them better than LCD displays, as CRTs usually have a wider color gamut. Usually twice the gamut "area" on that sharkfin pattern.
Using a larger VGA CRT for a HDTV display:
It's fed by an RCA DirecTV ATSC and satellite box, which works on ATSC without a satellite subscription.
Old 07-03-2011, 11:33 PM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
I used to have one of those Gateway Destination 36" CRT VGA monitors in my basement. It could only do 800x600, but I loved it. I loved to play emulator games on it with a PC. I also liked to watch TV and movies on it with an external tuner box. I sold it to a friend when I moved into a smaller house.
Last I knew, my friend still uses it as his bedroom tv.
I moved again recently into a larger house. I just might have to get that monitor back... I need a garage TV
Old 07-04-2011, 05:37 PM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
I remember in the late '90's going to a Gateway 2000 store and seeing demonstrations of those Destination PCs. HTPCs were a novel concept back then.
Old 07-05-2011, 05:26 PM
site123a site123a is offline
blank
Old 07-05-2011, 08:57 PM
CoogarXR's Avatar
Originally Posted by site123a View Post
I have one these Toshibas, the 15" monitor for it has a dot-matrix LCD readout below the screen, and function buttons around it for the computer. I thought that from pretty unique since I've never saw that on any other CRT monitor before, or after. That's the only reason why I kept the system...
Pics!
Old 07-05-2011, 10:30 PM
blank
Old 08-15-2011, 01:52 PM
waltchan waltchan is offline
It's too late to collect as most are now at e-waste centers.
Old 08-16-2011, 11:08 AM
cbenham's Avatar
cbenham cbenham is offline
I have several PC CRT monitors that are capable of various V&H scan rates. They are capable of up to a 180 Hz refresh rate. I was hoping to use one for a CBS sequential color monitor requiring H=29160 and V=144.
The problem is that they all seem top be "programmed" to lock only to specific combinations of standard scan frequencies.
How does one unlock the programming to allow this oddball H=29160 and V=144 scan combination? Thanks for any help.
Cliff
Old 08-16-2011, 11:37 AM
Old 08-16-2011, 11:46 AM
I have a Hewlett-Packard mx70 monitor I use with my PC. It had a great image when it was new some five years ago (more or less), but about a month ago I noticed the raster was bending rather severely, as if the auto-degausser had quit. I tried everything I could think of to restore the raster to its proper size and shape -- pincushion adjustments, centering, positioning, you name it (this monitor has quite a few adjustments for raster parameters such as pincushion, pin balance, etc. in a menu called "advanced geometry") -- but, try as I might and did, I couldn't get it right, and I fiddled with the thing for days.
I was about ready to throw in the towel and get a new flat-panel monitor. As I write this, however, three weeks or so later, the problem seems to have corrected itself, as now the raster is 99.9 percent straight (still some very slight curvature, hardly noticeable, at the extreme right side of the screen). What could have caused this problem, and why did it go away on its own? I thought these problems only got worse with time, until the monitor either went up in smoke or the raster was so distorted as to be completely unusable.
BTW, I wonder if the MX70's pincushion correction is digital. As there are no potentiometers for setting brightness, contrast, etc. (as I said, everything on this monitor is controlled through software; all adjustments are made via menu selections and bar-graph controls, activated by "select" and +/- buttons on the monitor's front panel), I would think the mx70 is at least partially digital.
Old 08-16-2011, 06:18 PM
CoogarXR's Avatar
This will be of no help, but this reminds me of when I was an IT guy, this woman said that every morning her screen flickered and distorted. Only in the morning, and never again, and never when I was around.
I finally solved it when I was in the next cubicle over, to work on that PC. When I turned on the monitor, she yelled "there it did it!". Here it was the degaussing coil in the next cubicle interfering with hers when the person in the next cubicle turned on their monitor in the morning. Their monitors were back to back, with the cubicle wall between them. LOL
Old 08-16-2011, 06:41 PM
MelodyMaster's Avatar
MelodyMaster MelodyMaster is offline
78s Galore.
The only CRT monitors I'm saving are the 14" TTL amber that came with the original IBM XT, (Plus the PC itself) An EGA 9-pin 9" Electrohome, and a 22" Sony with DVI.
Old 08-17-2011, 11:11 PM
basil lambri basil lambri is offline
I had a VGA CRT monitor for my old Dell computer from 13 years ago. When I bought the computer that I am using now (Compaq) a few years ago it came with an LCD monitor.
About 2 months ago I tried to use my old CRT monitor with my new computer just to see what it looked like. It had a very nice picture. But after a few uses with my new computer the CRT monitor broke. My guess is that such an old monitor couldn't keep up with the speed of the new computer. I threw the monitor away. Oh, well!
Old 08-18-2011, 12:22 AM
Not all of them.
There's a Thrift Store near me that always has a rack full of CRT Monitors, everything from an E-Machines to Sony, most still work and most are $5.00.
They generally aren't terribly old, mid 90's and up.
If I had room I'd grab a nice 21" model just to have. I had a Sony but got rid of it when I got this HP LCD, so much space saved on the desk by doing that!
I do still have a 15" Sony that I got new about 10 years ago, it works but the CRT seems to be getting old, it's not as sharp and bright as it used to be (but neither am I)
Old 08-19-2011, 10:44 AM
freakaftr8's Avatar
Convergence freak!
There was a 14" and I believe a 9" Sony Trinitron monitor that was produced around the late 80's. It was VGA and would do 800x600 interlaced. They were cool and I used to have one in my office connected to and old 386SX (Laser) was the make of the computer. You guys remember those, lol, believe it was an old Price Club branded computer. The Sony monitor however only had the EGA 9pin, but there was a converter cable that would connect it to a 15pin VGA. THe monitor also had the old VTR olive green connector too. It looked strangly similat to the 80's small professional broadcast monitors.
