Old 06-14-2011, 02:34 AM
Econoquick means there is no instant on circuit. Sony claimed to have improved the warm up time for their CRTs which no longer needed an energy wasting instant on supply, but I've never compared the cold start time.
I think all of the Sony sets I have owned, and installed/worked on in airports, have been at full brightness within 10 seconds or so, back to my 1979 KV-1922. Once the CRTs get weak, though, it takes much longer for what brightness you do get...
Old 06-14-2011, 10:33 AM
Smile
Originally Posted by Sandy G View Post
KV-5XXXs of ALL iterations are STILL highly sought after, & tend to go high, even after what, 30-35 years ? There IS something magic about "Sony Trinitron", after all...
I couldn't agree more. :-)
Old 06-14-2011, 12:27 PM
kx250rider's Avatar
REAL TVs have TUBES!
Are you sure about that? I'm almost sure my 5100 doesn't have instant one. I thought the quick warm up was due to the unusual directly heated cathodes in the CRT.
I stand corrected... The KV-5000 and 5100 both have non-instant filament supplies which come from the FBT, and being that the both use the same CRT (SD-59), I don't know why only the 5100 has the "econoquick" badge. I got confused with the KV-9000, which does have instant on and a separate filament supply transformer (I double-checked before stating this time, LOL).
Thanks for pointing that out, and sorry for making an assumption based on a bad memory of models ...
Charles
Old 06-14-2011, 12:59 PM
I have seen 5000s both ways, I presently have a 5000 with the "econoquick" logo below the UHF ch selector knob. My earlier 5000 (which was stolen) did not have the logo. The manual that I still have from my first 5000 does not show the logo.
S0ny sometimes takes a while to "invent" these terms... The first "Walkman" was just called a "TPS-L2"
Old 06-14-2011, 01:10 PM
Old 06-14-2011, 06:29 PM
If you you still have your KV 5000 manual, is there a print date shown any where? I'm trying to establish a valid introduction date for both the 5000 and 5100.
Old 06-14-2011, 07:21 PM
Sorry, None given, that is one of the first things that I checked for after I dug it out. There is a part number 4-495-409-21 (1) perhaps a S0ny expert can figure it out from that?
Sams Photofact for the 5000 is 1457-3 (early 1975) and for the 5100 is 1652-2 (mid 1977), if that helps.
Old 06-14-2011, 08:18 PM
Sony sometimes takes a while to "invent" these terms... The first "Walkman" was just called a "TPS-L2"
There are versions of the TPS-L2 with and without the name "Walkman" on them. I remember selling every one of those we could get our hands on, in a little store in Evanston, Illinois in 1980-81.
Old 06-15-2011, 09:40 AM
kc8adu's Avatar
kc8adu kc8adu is offline
i have a kv-9000 that i fired up after it sat 7 years.first firing took about 45 seconds to fully brighten up.about 20 from cold and instant if it has been plugged in.i guess this one dodged the slow death of instant on!it still look great on the lone analog station we have here.
i have several kv-5xxx sets here too.the 5200 is ready in about 6 seconds.however these directly heated tubes have an odd failure mode that i have seen several times.k-k leakage.i replaced the crt in the 5200 for that reason.
email for more info
Old 06-15-2011, 11:56 AM
kx250rider's Avatar
It probably had a new face bezel put on due to scratches. Many of them did, and in fact, the shop I worked for in the 80s, kept 2 or 3 in stock. There was no option to order the early one without the Econoquick badge, so they all had it when replaced.
Charles
Old 06-15-2011, 12:01 PM
kx250rider's Avatar
I have both of the original Sony manuals, and the original 1st ed's are dated:
KV-5000 = 1973
Supplements and corrections as late as 1994.
KV-5100 = 1976
Supplements and corrections as late as 2005.
By memory, the last KV-5100 I saw new in a store, was at a Sony authorized retailer in West Los Angeles in 1981. It could have been on the shelf for a couple years, much like a drug store in Northridge, CA which had a few Panasonic CT-101s in stock til 1994 (was a 1982 set). Small and expensive TVs seemed to sit awhile.
Charles
Old 06-15-2011, 03:40 PM
kx250rider... good thought about the replacement bezel... they do seem to scratch easily!
Speaking of 5" 'trons, has anybody seen one of these before?
http://cgi.ebay.com/Sony-Trinitron-K...item2c5d5ec3e4
not affiliated,
Old 06-15-2011, 04:28 PM
IIRC, the 5" Trinitrons had the same kind of "Cachet" that their older B/W brothers had back in the early '60s...Both were kinda "jewel-like", performed VERY well, & were fairly expensive when new.
Old 06-15-2011, 04:57 PM
KV-5000 = 1973
KV-5100 = 1976
Charles
Good stuff. I saw your previous thread where you dated the 5 inch Sony's. Wanted to be sure on the dates.
Old 06-15-2011, 05:05 PM
not affiliated,
No! Interesting. Looks to be a Japanese market model with 100 volt power supply. I believe Japan is NTSC, but previous experience with Japanese market sets: won't accept a digital converter box signal. I could be wrong on this. It still has video/audio inputs, but not sure about that power supply working properly.
The tinted screen cover can be removed easily. You can use a jeweler polish paste to remove most scratches. Several applications will remove all but deep scratches. I use a product called "HAPPICH" product of Germany.
