Old 02-23-2011, 10:31 PM
My RCA CTC185 19" table model, bought new in November 1999 (probably was made for the 2000 model year) is 11 years old and still works as well as the day I bought it. Only had two repairs on it in all that time, both for the same problem -- the antenna connector broke off the tuner PC board. A local TV technician, the same one who repaired the RF port problem the second time, told me there is a problem with the jungle IC that could affect OTA reception, but I haven't noticed any difference to date since I have never used this set on an antenna, only on cable (I live in a near-fringe area for Cleveland TV, about 40 miles from the transmitters). CRT is in great shape as well, but since I only have basic cable (broadcast channels only) I don't watch much TV except the news, a DVD or two in the evening, and once in a while I'll watch one of my old VHS tapes or one or more time-shifted programs. I predicted, a few years before the DTV transition, that I'd be using this set when all TV went digital in 2009, and my prediction was right on the mark -- I am still using it, with my Zenith Sentry 2 in standby, to this day.
I guess my CTC185 must have been made before RCA/Thomson sets went downhill as far as quality goes; the only real problem with the CTC18x series was the infamous onboard tuner on which the grounds would come loose, leading to noise getting into the control circuits and often ruining the jungle IC. Aside from that, the CTC185 and its successors are great TVs and, once the tuner issues are resolved, will run for many years with excellent pictures. I decided that I won't get a flat panel TV until my CTC185 quits, and even then I'll hold off on getting one until my Zenith Sentry 2 dies. The way my RCA set is going, however, and given how little I use it, that day may not come for quite a while, as the RCA just refuses to die.
RCA also got it right (finally) starting with the CTC203 series, in which the tuner is mounted remotely from the main PC board. I'm convinced that the OB tuner was the single biggest problem the CTC18x series had; now that this has been solved, the newer sets may go for years without seeing the inside of a service shop, although these days it seems that more older sets (meaning more than five years old in the case of FPs) are being recycled or otherwise disposed of, and replaced by new ones, rather than being repaired. Not good news for the repair shops (except those shops specializing in warranty service). This actually started years ago, with cheap tube-powered TVs made by Japanese/Korean/Pacific Rim-based electronics firms. I had a "Kenco" branded B&W TV in the mid-'70s that lasted only three years before going belly-up. By contrast, I bought a Zenith 12" solid-state b&w portable in 1978 that lasted 22 years, and was still going strong when I replaced it with the RCA CTC185. The Zenith was trouble free all that time, except for the UHF tuner detent mechanism breaking some time in the eighties, jamming the UHF tuner on one channel. Cleveland only had two UHF stations, one independent and one PBS, at the time, and since I only watched network stations (channels 3, 5, 8 in my area then) the jammed tuner was not an issue. The TV itself worked well, and that was all that mattered. I hope whomever picked up the set off the trash pile behind my apartment got as much enjoyment and good service from it as I did.
Old 02-23-2011, 11:07 PM
I've seen a fair amount of flyback failures with CTC185 sets, mainly in the 25"/27" sets. Although I have seen the problem in a few 19" sets. Other than that, these sets gave the usual problems that any other TV gives.
I guess the last decent RCA chassis was, IIRC, ATC113. This chassis was very similar to the CTC203. Except for flyback failures and loose connections in the horizontal drive circuit, the CTC203's and ATC113's were decent sets. Again, the larger screen sets (31"-36") that used this chassis suffered the most flyback failures. I think where they made their mistake was using a flyback that was designed for a smaller screen size in their larger sets.
The TV's that really ate flybacks, and caused other problems, were the post ATC113 sets. These sets were Chinese built and are not worth the effort.
Old 02-24-2011, 07:51 PM
Wizard256 Wizard256 is offline
CTC203/ATC113 are good stuff, but there are many exceptions, I worked on them for a living and know them rather well.
There were 2 early and late CTC203 chassis systems. The early ones is MUCH better as you do not have to worry about unreliable gemstar module and all you do is unhook the one ribbon connector and you are done since board already have micro controller on the mainboard. The late CTC203 and all ATC113 used gemstar module with 2 ribbon cables as micro controller (unreliable in 3%).
L14401 solder failures were caused by hot glue of very unique properties this one DID creep wide and far, down the leads of components, especially L14401 (subsonics vibration and thermals cycling plus glue creep broke the solder bond. Getting that glue out of the through hole is key for total success. Can't just resolder! Ditto to older chassis that had horizontal driver transformer that had RCA unique hot glue applied!
Fly failures were always the 32" and 36" of any rca chassis from CTC175 onwards.
CTC169 is a genuine, purely genius design. You have to study the theory of operation and schematics and get understanding of power supply and vertical circuit which is what a hoot (efficient!) and power supply control/feedback. I had good luck with them except for occasional bad CRT that shot the one transistor on the chassis.
PS: Those TV/VCR combos one thing you did bad thing instead of throwing out, should had tried to take apart that mode switch, polish with little heatsink paste (excellent polisher) and swab as polisher, once the silver-plated contacts are bright and free of tarnish, then clean up using swabs dipped in alcohol. Finally to prevent tarnishing use silicone grease on mode switch contacts. This fix will stop the shutting down problem after turn on.
Cheers, Wizard
Old 02-25-2011, 01:23 PM
Zenith26kc20's Avatar
CTC169, yes, that is a engineering marvel! I have repaired many and consider it one of the best TVs ever made! Orion tv's aren't too bad. I've repaired a few!
Another hated TV here is the Sony BA6 chassis.
And any plasma.....
