Old 11-15-2010, 09:13 PM
ctc17 ctc17 is offline
You are going to have to remove the transistors to check them. The .005 from e b is most likely measuring the driver transformer.
Try checking the rectifiers in circuit. One meter lead to chassis and the other to blue wire one then blue wire two. Then flip the meter wires. Should measure around .450 on one and open (what the meter displays without the leads touching anything) in the other direction. If it measures something and slowly moves to open that just the caps taking a charge.
NM on the driver transformers, one just looks new or different. It could just be the flash reflecting off the wax in the paper.
Old 11-15-2010, 11:20 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
Here's what happens... Both of the rectifiers start out with a high reading, sometimes as high as the .450 you mention, then it quickly goes back to .002-3 or so. Doesn't matter which polarity I use.
From Captain Video, 1/4/2007
Old 11-15-2010, 11:37 PM
That sounds backwards but not shorted. Pull the transistors and test them.
Old 11-16-2010, 08:57 AM
Carmine's Avatar
Using the diode scale, here are the transistor readings once removed (green/blue = alternate polarity):
Note that I did not measure the pre-drivers because they have three legs and I was unsure how to measure them.
Old 11-16-2010, 10:49 AM
All of them have 3 legs, the 3rd leg on the big ones is the case. Let me see if i can make you a quick video on how to test them.
Old 11-16-2010, 12:05 PM
Carmine's Avatar
I think I figured out which leg was the case.. The one that doesn't sit directly across from another... Sort of the odd-man-out, or top of an isosceles triangle?
If so, I measured them and came up with the following two readings. I had to move the meter from Diode to 2K ohms before they had a reading. Both read higher, and quickly ticked down to these more stable numbers.
1.716, infinity & 1.650, infinity.
Old 11-16-2010, 01:28 PM
here you go. http://www.youtube.com/watch?v=REW2lF0sb74
painting all day, be back later. Germanium transistors may show some leakage but no shorts
Old 11-16-2010, 01:52 PM
Old 11-18-2010, 12:07 PM
Carmine's Avatar
Latest update:
I went to my local electronics supplier (not a chain store, I wonder how long that website has been "coming soon"?) and they looked at my original fuse as if it were from another dimension... In other words not only didn't they have it, they had never seen another like it, and these guys don't sell mobile phones and X-boxes. It was an odd fuse, having small tabs that lock it into place.
Although I hate modifying things from original, rather than hunt for an unobtainium 3.5 amp fuse, I soldered in a 4 amp circuit breaker that fit as if the chassis had been designed for that all along.
Then I put everything back together, but only used one screw in each transistor... Figuring that I'd be removing them one at a time to find a bad one. I fired it up, but soon realized the second screw must secure the third leg (ground?) of the transistor. I came right on, but only from the left channel and the bass sounded like garbage even at low volume. I let it run like this for a few minutes, then shut it off and felt each capacitor can. They were actually cold. (This is Michigan in November after all.)
So I powered down and added the missing screws. Volume was set all the way down, but as soon as I powered on, the loud hum of death came from the speakers. I immediately shut it down, and saw just a wisp of smoke from the chassis. It might not have been on long enough to even trip the .5 amp larger breaker.
Couldn't feel anything warm, and a "sniff" test only revealed a slight smell around the upper transformer (as seen in the under chassis pictures). I suppose my next step might be to pull all of the power transistors and keep adding them until something bad happens again, or test them out of circuit as was suggested by CTC17 and Andy.
Have to do a few other things before I fool with it again tonight, but in the meantime your thoughts are always welcome.
Old 11-20-2010, 10:53 AM
Carmine's Avatar
If I have a bad transistor, I can't determine B vs. E if E is shorted, correct?
Therefore, going by the B & E markings on the transistor socket, my output transistors would look like this:
B E
c
When I check two of the matched transistors, I have continuity between E & C in both directions, in other words, shorted. On the other two transistors, I have "some" resistance between E & C, but definitely not infinite.
This would indicate all four output transistors are shorted?! Could some massive failure have taken out all four?
Old 11-20-2010, 11:48 AM
Did you watch my video on how to check the transistors?
The circuit breaker is a BAD idea. Its response time is much much to slow. Where a fuse will blow in quarter of a second the circuit breaker will hold on for several seconds and cause more and more damage,
Get that out of there and put a regular fuse holder and AGC style fuse in, and if a 3.5 amp is not available go with a 3 amp.
Ohh, dont forget the light bulb trick I told you. That will save you a major headache.
Yes on the transistor case. On diode check you should get no reading from C to E, it should be open. Emitter, Base, Collector. Non of them are grounded.
Old 11-20-2010, 01:34 PM
Chad Hauris's Avatar
If it were me I would replace all the electrolytic capacitors first...this process has never let me down....also new rectifier diodes would be a good idea too.
On jukebox amps when I had indication of a short, first I would replace all caps and remove the output transistors, then power up the unit with the test lamp in place of the fuse. If the lamp is dim the problem is in the outputs. Don't remove the test lamp until you have fixed the problem. The lamp will allow enough current through to allow the amp to work once you clear the short but will light up and prevent further damage if the short recurs during testing.
Also I would not test it on the speakers in the console if possible...have seen cases where shorts in output transistors or caps destroyed speakers by putting DC into them.
And make sure the insulation is right such as mica wafers between the output transistor case and heat sink when re-installing them.
Chad Hauris
Old 11-20-2010, 05:59 PM
Carmine's Avatar
Yes, thank you for posting it. As I said, I am seeing some amount of continuity between C & E, in both directions... Even if I have mis-identified E vs. B, I should not be seeing any continuity with C in both directions, correct?
Noted. I'll change it out and try the light bulb.
As I mentioned, I haven't the time nor inclination to shotgun all the caps in this thing. I don't think I learn anything that way, and it's not all that "fun". If that's the best we can do for diagnosis, this console will probably just end up on a curb.
Old 11-20-2010, 08:43 PM
If the transistor is not shorted you can easily identify the Base using this method. I will be the pin that gives you .2 -.5 volts between it and the other two leads. Say if you hold the black lead on B and move red from E to C and get .450 on bot E and C you know the black lead is on B. Now if you reverse red and black it should read open.
