Old 11-04-2010, 01:51 AM
RitchieMars's Avatar
RitchieMars RitchieMars is offline
VK Member
Really? Huh... let's see. Trying this with a 6SN7, lowering the filament voltage sort of bumps it up a tiny bit, and then it drifts back to about where it was. A 6BK5 does about the same, it shifts but lingers about in the same spot, maybe just a hair higher. I also tried a NOS 12BY7 which reads around 68, also a very small shift. But... my 12AX7 tests good at about 60 with the filament set according to the manual, but if I drop it as you suggest... it's bad at 20 on both grids. That's the 12AX7 in my Zenith that controls the A.G.C and serves as the vertical oscillator.
Old 01-01-2011, 03:44 PM
zapro zapro is offline
VK Member
Wow what a nice find! That's real bargain at 5$ apiece!
Well the reason that TV's does not use Electrostatic deflection for ther CRT is that if you were to deflect a 110° CRT electrostaticly you would need 7000-8000 volts to move the beam the +/-55°. It is not practically to do this.
The reason scopes used Electrostatic deflection is because it is linear, and way faster than magnetic. The magnetic deflection has a large inductance, and moving the beam fast requires a LOT of power.
// Per.
Old 01-23-2011, 10:34 PM
Tube Radio's Avatar
Tube Radio Tube Radio is offline
Also the larger the CRT the longer it has to be in order for electrostatic deflection to be used practically,
Main system
Scott LK-72A amp & LT-110 tuner
Garrard Zero 100C turntable
AKAI GX 255 RTR
iPod & computer
DIY speakers (upgrading them soon)
