Old 09-30-2010, 05:30 PM
Old 09-30-2010, 08:42 PM
mwplefty's Avatar
mwplefty mwplefty is offline
Only if your system has analog cable channels in the 65-125 range. Even then, it doesn't work well because older UHF tuners aren't as selective as VHF tuners.
I get 2-31 (minus a few channels in-between), 70, 96, and 98. So could I possibly get a few channels?
Old 10-02-2010, 08:14 PM
Robert Grant's Avatar
The one caveat about cable hookups these days is that a few of the systems out there are entirely digital. If that is the case, you won't see anything but "hypersnow" on an analog set, and no converter (other than one rented from the cable company) can fix it.
More common is what one very large CATV corporation is doing - offering only some of the programs available over-the-air (the ".1" channels) in analog.
If your cable system offers many channels in analog (you can test this by plugging the cable into a "BPC" set made from the late '80s to 2005).
For analog cable systems using the midband and superband channels, there is one really cheap solution for using an old "knob" set - a used VCR. Nearly all VCRs newer than about 1989 have a cable-ready tuner, simply leave the TV on channel 3 (or 4) and use the VCR tuner for changing channels. Now that so many people are using DVDs for movies and TiVos for timeshifting, VCR are abundant and selling for about $7 at thrift stores.
Old 10-02-2010, 09:37 PM
mwplefty's Avatar
I have a VCR from around 1998 that we haven't used since we replaced the 27" CRT in our basement with a Samsung LCD in late 2007. I'm going to hook that up to another unused set in our basement and see if it still works. If so, I could probably just it hook up to my old TV with the knobs.
Old 10-02-2010, 10:59 PM
mwplefty's Avatar
Ok. So I hooked up the VCR to a newer (5-year-old) set with a digital tuner just to test it. Surprisingly enough, the VCR didn't need to be plugged in for the TV to get a signal.
One very strange thing I noticed was that I get less channels with the VCR. When I use the VCR to change channels, I only get channels 2-19, while when I use the TV to change channels, I get channels 2-31, 70, 96, and 98.
Does anyone know why that might be?
Old 10-02-2010, 11:20 PM
If you have the remote for the VCR, bring up the on screen menu. There should be an option to scan for channels. Once you perform a channel scan, the VCR should receive the same channels as the TV that you used as a test.
Old 10-02-2010, 11:37 PM
Dave A's Avatar
Dave A Dave A is offline
MW,
Your VCR probably only has an ATSC tuner for over-the-air and a NTSC tuner for the now-gone cable world giving you the 2-19 world. Cable clear channels are QAM which is probably in your set tuner along with the NTSC/ATSC tuner when you bypass the VCR giving you the upper channels. VCR tuner fair, set tuner better. And the added few analog channels still sent by cable will appear.
My Phila Comcast system is mostly digital but the locals are still analog and QAM HD, including sub-channels, (very good compared to what a digi box does to the signal in pure digital) and a bunch of useless other channels in NTSC. I do get a bunch of music channels though. All this on a Sony XBR960 HD glass set with the NTSC/ATSC and clear-QAM tuner via the basic Comcast delivery to that set.
All that said, I have the Comcast mini-box on my other two relics. They do look ok but the audio is low on both.
Old 10-03-2010, 01:40 AM
mwplefty's Avatar
Originally Posted by Dave A View Post
MW,
Actually, I scanned for channels on the VCR when it was set to "CATV" and got channels 2-31, 70, 96, and 98.
My neighbors recently talked about how they no longer receive channels 2-99 with basic cable (They only got about 15 channels or so). They had to buy a separate box in order to get the additional channels.
Could this be why I'm only getting a certain amount of channels? Do I need that digital cable converter box to get all channels 2-99 now?
Either way, I'm pretty glad this VCR of mine still works. Even though we've had it for about 12 years, I can't remember that many times using it. Therefore, for a while, I thought it was broken and useless. I'm happy that I was wrong.
Old 10-03-2010, 11:28 PM
Your neighbor (and thus, in all likelyhood, You) probably use that really big cable company I was referring to. They are gradually "moderinzing" their cable systems with the same plan. Instead of running a whole new network of cables to every subscriber in their system, they are dropping (drastically) the number of NTSC (analog) channels they provide, and having subscribers attach a digital converter box (much smaller than those used for over-the-air DTV) to every TV and VCR in their homes.
On the one hand, freeing up all that bandwidth used for 70ish NTSC cable channels so it can be used for PPV, on demand, Internet and telephone service without drilling more holes and mining more copper seems commendable.
It also stops basic cable subscribers from running illegal cable splits to their non-paying neighbors (who can blame the CATV company for wanting to stop that?).
On the other hand, it could introduce hidden price increases (not being on one of their systems, I don't know if they are charging customers for the boxes or not), and it does invariably take some working sets out of service (even if the cable company were providing a limitless number of boxes, few people would actually hook up, say, seven TV sets).
Old 10-04-2010, 03:45 PM
mwplefty's Avatar
I'm all for that, but being a pretty nostalgic person myself, I believe that eliminating all analog cable (and full-powered local analog channels) and requiring new digital cable or converter boxes takes away from some of the TV set's originality and style. As I mentioned before, turning the VHF/UHF rotary tuning knobs to change channels, in my opinion, makes the set what it is today and gives us that connection to what TV once was (for many years).
Believe me, how many of your young(er) friends or family members are intrigued by turning that knob to change the channels? I sure as hell was when I used to go to my grandma's house and use her 13" RCA from late-1979 while playing pool in the basement. (Now my family is talking about getting her a flatscreen LCD TV, since the RCA XL-100 hasn't worked since the DTV transition. I'm trying to convince them otherwise).
Old 10-04-2010, 06:16 PM
Old 10-29-2010, 12:12 AM
mwplefty's Avatar
The most annoying thing about digital cable is that even if you have a QAM (digital cable) capable TV, the basic digital channels are usually encrypted. This means that you need a cable card capable TV. The problem is that my cable company charges $45 for a service call to install cable cards, and $3 a month per card. It also took about three hours, and three visits for the cable guy to get my Tivo's cable cards working.
Speaking of Tivo, I remember quite well trying to hook up Tivo to our circa 1992 Sony Projection TV a few years back. I thought that being able to record TV shows without a VHS was a luxury I longed for (our VHS player was really crappy when it came to recording programs). When cable was still broadcasting in all analog (in other words, the good old days), I tried to hook it up to the VCR, which would've required about several additional adapters plus a modular phone line (something we did not have in that area of the house). I eventually just gave up, and within a year, we got Comcast Digital with DVR. Nowadays, being so busy, I can't imagine not having some sort of video recorder. I rarely have time to watch live TV anymore.
